Please help! System low on memory. at DVinfo.net
Old June 8th, 2010, 08:10 AM   #1
When I render a project I keep getting an error message that says the system is low on memory and rending stops. Pleas Help!
Thanks!!!
Darin Holiday is offline   Reply With Quote
Old June 8th, 2010, 08:33 AM   #2
Darin,
go to preferences in Vegas go to video Tab and change the number of processors down to 2 and reduce the amount of ram down to 56. This is not a fix, but is a band aid that will probably allow you to get through the work.
Curiously, are you in version 9 in 64 bit land?
DATS ALL FOLKS
Dale W. Guthormsen
Dale Guthormsen is offline   Reply
