wobbly footage when converting HDV to SD (DVD PAL) at DVinfo.net
Old July 14th, 2010, 03:02 AM   #1
hi there
I have some HDV clips from my Z1 that I am trying to down-convert to SD for a DVD.
I have put the clips in an HD timeline (for HDV) and then rendered to various DVD PAL settings (DVD architect compatible, widescreen, PAL DVD) to see the best results.
the problem is that, after rendering, when I playback the final mpeg2 (opening it with windows media player for instance) I see a lot problems when there are fast pans or any shot that's not almost still.
the lines and contours become distorted to different degrees, as if one of the settings was wrong.
difficult to explain but it looks like the image becomes all wobbly during pans...
I haven't experienced this converting the same clips to WMV9
what am I doing wrong?
Federico Perale is offline   Reply With Quote
Old July 14th, 2010, 06:19 AM   #2
not even one response?
reading articles I see that a problem could be field order....
but Vegas should adjust the field order from HDV to PAL DVD automatically right?
Old July 14th, 2010, 06:43 AM   #3
Sponsor: JET DV
As an experiment, you could try changing the field order of the clips on the timeline and rendering it out. That way you would know for sure if that would help.
Another option might be to render out to a PROGRESSIVE DVD. Then the DVD player would add the proper interlacing back in.
Old July 14th, 2010, 07:34 AM   #4
Hi Federico
Edward is usually correct..it certainly sounds like a field order problem..you are rendering an interlaced upper field first to lower field first by default AND resizing the video (from 1440x1080 to 720x480 or 576)
That will totally mess up your footage (in fact even if the fields were both lower first it would STILL mess up any footage.
Solution is simple..you need to de-interlace the source first so set your de-interlace box in project properties to "interpolate" (since you have motion during panning) and set the render quality to "Best"
Render a portion of the clip again to MPEG2 Widescreen and you will find that the problem has gone away!!
Chris
Old July 14th, 2010, 07:54 AM   #5
hi Chris
I will certainly try but shouldn't the template DVD PAL serve this purpose?
I thought Vegas would automatically adapt to the output file needed no matter what starting file you use....
so everytime I need to convert HDV 50i to PAL DVD I need first to de-interlace? there is no direct way of doing this?
Old July 14th, 2010, 01:19 PM   #6
how do i do this?
Old July 14th, 2010, 01:48 PM   #7
I have managed to remove the bigger "wobbliness" by selecting "BEST" in rendering options
ok....now it works fine...
I just set field order to "none" and now it seems to work
tried with a DVD and it plays just fine......
but I have to say, Chris, that your solution works even better....deinterlacing the source first is the best result so far even for the pans
Old July 14th, 2010, 05:00 PM   #8
Vegas will de-interlace the footage automatically for you as long as you set it up in Project Properties. Zap in the settings and then check the box that says use these settings for all new projects.
You might be able to save the Project properties as a new template also which will save you typing in the boxes..not sure but Edward will know.
If you shoot HD interlaced (like 50i or 60i) and are rendering down to SD then you MUST de-interlace otherwise the footage will give you strange interlacing lines that are messed up during the downsizing. Of course, if you are shooting progressive then it's not needed!!
Take a look at this page..you will probably recognise your problem there too!! What is deinterlacing? The best method to deinterlace movies
Chris
Old July 14th, 2010, 05:35 PM   #9
thanks
does the same problem happen whenever I want to downconvert to a lower resolution?
I have some mild interlacing issues with a full HD file I rendered to HDV WMV9
but strangely I also have some mild interlacing issues with the same file rendered to full HD WMV9
am I required to deinterlace everytime use shoot interlaced?
also you say "Zap in the settings and then check the box that says use these settings for all new projects." but if I do that when I shoot progressive isn't going to be an issue? will I need to remember to change it?
Old July 15th, 2010, 06:30 AM   #10
Sponsor: JET DV
Part of the problem is downsizing. Changing to "Best" on the render is vital when you're downsizing as it uses a different resizing routine than "Good" does.
As for saving different project settings, just go to file - properties, change the settings as desired, type in a new name in the preset list box, and click on the floppy icon to the right of that box. You can easily create multiple presets.
Edward Troxel is offline   Reply
