Close Gap Script at DVinfo.net
Old July 21st, 2010, 01:38 PM   #1
Close Gap Script
I am having a problem trying to get this script to work
* Program:
* Description: This script will Delete Empty Space Between Events In Selected Tracks
* Author: Philip
* Date: August 31, 2003
import Sony.Vegas;
import System.Windows.Forms;
import Microsoft.Win32;
//time intervals for split events.
try
// step through all selected video events:
var FirstTrack : Track = Vegas.Project.Tracks.Item(0);
for (var track in Vegas.Project.Tracks) {
if( !track.Selected) continue;
var tracktime = new Timecode(0);
for (var evnt in track.Events) {
var currTake = evnt.ActiveTake;
var CurrOffset = currTake.Offset;
evnt.Start = tracktime;
currTake.Offset = CurrOffset;
tracktime = tracktime + evnt.Length;
catch (errorMsg)
MessageBox.Show(errorMsg, "Error", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
I have it installed in Vegas Pro 9e and when I run the script it says that "An error occured during execution."
Error 0x80131600
Details are
C:\ProgramFiles\Sony\VegasPro9.0\Script Menu\DeleteEmptySpaceBetweenEvents.js(1) : Invalid character.
Any help would be appreciated.
Last edited by Jim Schuchmann; July 21st, 2010 at 02:53 PM. Reason: Corrected the Script to work
Jim Schuchmann is offline   Reply With Quote
Old July 21st, 2010, 01:48 PM   #2
Sponsor: JET DV
Is that the entire script? What's on line 1 of your .js file? It should be /** so if you have something else there, delete it.
Old July 21st, 2010, 01:54 PM   #3
That is the entire script. I checked and there was a space following/**. I removed it and it still reports the same error.
Old July 21st, 2010, 02:29 PM   #4
Sponsor: JET DV
This modified version worked for me. However, the problem I found was with the spelling of "currOffset" instead of "CurrOffset". Copy this version and replace your text with this:
Code:
* Program:
* Author: Philip
import Sony.Vegas;
try
catch (errorMsg)
Old July 21st, 2010, 02:41 PM   #5
Thanks for your help Ed.
The first part of the problem that I was having was the fact that I was creating this script in a word program and not in "Notepad". When I would open the file in my word program, it all "looked" good. When I opened it in "Notepad", it showed machine language instead of the characters I had typed.
As a Newbie to scripting I now "know" that to create or modify a script you must use "Notepad". I wonder how many other newbies have made this mistake and given up on scripting.
Hope this helps some others out there.
Old July 21st, 2010, 02:47 PM   #6
Sponsor: JET DV
Yes, you definitely want to use a "plain text" editor. For those that have it, Visual Studio can make things even easier and you can set it up to do code completion for you - including the possibilities for Vegas. Makes it much easier when you can't think of the actual property name you want to get a list to choose from.
Edward Troxel is offline   Reply
