DVDA and audio at DVinfo.net
Old September 21st, 2010, 03:39 PM   #1
DVDA and audio
I'm fairly certain I know what the answer to this is going to be but I just have to ask,
A client brought a HD h.264 file with a 5.1 surround ac3 to burn to Blu-Ray. Opening the files up in DVDA was no problem HOWEVER it seems whomever did the original encode for the file rendered out the ac3 first then added about 5 seconds of black to the top of the video file and rendered that out to the h.264 (and it was all done in Compressor I believe.) Now the problem is that the audio is now off by, yup, 5 seconds.
Since Vegas can not open either the h.264 file OR the ac3 I was hoping I could just slide that little audio bugger on the DVDA timeline 5 seconds and voila, but it seems like that's not possible. And there's the rub, Architect can't slide the audio or add a little slug on either the video or audio timeline can it?
Michael Tobias is offline   Reply With Quote
Old September 21st, 2010, 03:55 PM   #2
I do not believe DVDA will allow you to move the audio or video. If you've got SoundForge I believe you could open the 5.1 file and add 5 seconds onto it and resave it with no loss.
Garrett
Garrett Low
www.GLowMediaProductions.com
Old September 22nd, 2010, 08:15 AM   #3
You can also use Audacity (free audio editor) Audacity: New features in Audacity 1.3 but you have to enable the FFMPEG Library:
Click 'Edit' > 'Preferences' and use the link to the FFMPEG Library.
It allows loading and saving of AC3.
Thomas Moore is offline   Reply With Quote
Old September 22nd, 2010, 05:15 PM   #4
Well I just ended up doing it in Encore. Surprisingly enough Encore will let you move the ac3 tracks around, but DVDA didn't? Well it's still Sony a zillion and Adobe 1.
But thanks for the tips.
