Almost going mad..aspect ratio at DVinfo.net
Old October 28th, 2010, 03:35 PM   #1
Thanks in advance guys.
But I am having a nightmare, 2 days trying to render this.
I have a wedding movie, event/pan crop to 1920 x 817(2.35:1)
Rendering to DV PAL Widescreen(so it displays nicely on a 16:9 TV)
Problem is on TV, the aspect ratio is fitting right to the edge. Looks like with black all around - in the centre is the movie.
What am doing wrong???
With all due respect, Yes I have used the search function on the forums and have messed for hours with 'maintain aspect ratio etc..'
Thanks in advance.
Joseph Kassana is offline   Reply With Quote
Old October 28th, 2010, 06:04 PM   #2
Save it in a 16:9 file (i.e., 1920x1080) with black bars above and below your video. Then render that to your DV PAL.
Adam Stanislav is offline   Reply With Quote
Old October 29th, 2010, 08:53 AM   #3
Are you using Vegas 9 or 10? They added a switch to the Project Settings which is "automatically adjust source media to better match project settings" - it can make your footage come out differently to how you expect it.
(In fact, I've logged a bug concerning this and masking with Sony although they first refused to accept it as a bug and have since ignored my post to them with an example file showing the problem)
The upshot is, I suggest turning this switch OFF (unticked) and then Vegas behaves more like you'd expect it to when rendering a project with a different aspect ratio to the source files...
Hope that helps!
David Johns is offline   Reply With Quote
Old October 29th, 2010, 09:59 AM   #4
Yes I am using Vegas 9. And yes David that was that is a bug!!! Annoyed me.
What I did was set the project settings to 1080 x 1920 and rendered to DV widescreen - seemed to work..
