question about audio in multi-cam at DVinfo.net
Old December 8th, 2010, 05:01 AM   #1
audio in multi-cam + Multi-angle DVDs
when I use the multi-cam function I only get audio from one of the video tracks
not sure what I am doing wrong....
when I instead use "insert video track" to create video in video, I have all the different audio tracks and can chose how to mix them...
another quick question: multi-angle DVDs are created at DVD architect stage or at Vegas stage?
I mean, I can obviously put different video tracks in DVD Architect, but I cannot really sync them as I do on the Vegas timeline
what's the workflow for multi-angle?
Federico Perale is offline   Reply With Quote
Old December 8th, 2010, 10:06 AM   #2
Sponsor: JET DV
When you use the multi-cam option to combine the tracks, make sure the audio tracks are NOT selected. Then they will remain individual tracks and you can edit them individually and use whichever track is best at any particular time.
Old December 8th, 2010, 10:16 AM   #3
thanks!!!
will check tonight!
Old December 8th, 2010, 11:41 AM   #4
Sponsor: JET DV
They are created in DVD Architect. What I did, was I made sure my FULL video had a chapter point where I wanted the "multi-angle" section to be. Then I could easily find where to drop in the other angles.
Old December 8th, 2010, 11:45 AM   #5
ok...but then how did you sync the new angle portion to the main video?
Old December 8th, 2010, 11:49 AM   #6
Sponsor: JET DV
I put the chapter point on the main video. When adding the secondary angle, I used that chapter point on the main video as the beginning point for the alternate angle(s).
Edward Troxel is offline   Reply
