Pro 10.0b is out - Merry Christmas from Sony
Notable fixes/changes in Version 10.0b
* Added the ability to configure encoded format, interlace mode, and quality of CineForm™ encoding. * Added 24p Blu-ray Disc rendering templates. * Decreased startup time when many OFX plug-ins are installed. * Fixed a crash that could occur when opening a project using a missing OFX generator. * Fixed a crash that could occur when using Save Media with Project with media that had stabilization applied. * Fixed a crash that could occur when replacing media with stabilization applied. * Fixed a crash that could occur when starting playback after reordering audio track effects multiple times. * Fixed a crash that could occur when loading a project using media generators if the Video Media Generators window was open. * Fixed some issues in AC-3 Pro rendering format (muted LFE channel when using the “2/0 (L, R) + LFE" template, enabled LFE option for "1/0 (C)" and "2/0 (L,R)" templates, don’t show "2/0 (L, R) + LFE" template for stereo projects). * Fixed an issue smart rendering to MPEG-2 standard definition. * Fixed an issue that could cause video track effects to be processed as pre-composite after dragging the plug-in to the post-composite position in the Video Track FX window. * Fixed an issue adding 5.1 surround plug-ins to the master bus in a 5.1 surround project. * Fixed an issue that could prevent FX Bus input meters from functioning. * Fixed an issue that could prevent FX from being heard in the Apply Non-Real-Time Event FX dialog. * Fixed time, tempo, and meter information passed to VST plug-ins. * Fixed a hang that could occur when using 32-bit VST plug-ins in the 64-bit version of Vegas Pro. * Fixed audio glitches that could occur when scrubbing in a 5.1 surround project. * Fixed an issue with OFX presets for fractional values when saved or loaded with certain language settings active. * Fixed an issue loading large presets for OFX plug-ins. * Fixed an issue with OFX plug-ins that vary output even with fixed parameters. * Fixed an issue that could cause OFX temporal frame access to be incorrect when rendering to a file. * Fixed an issue loading and saving OFX presets that contain large amounts of data. * Fixed an issue that could cause keyframes for OFX plug-ins to move to the start of the FX timeline. * Fixed an issue that could cause an Undo operation in the video FX timeline to move all keyframes to the start of the FX timeline. * Fixed incorrect results with certain OFX transition effect plug-ins when used on still images. * Fixed OFX keyframe interpolation for certain cases. * Fixed an issue that could cause the Stereoscopic 3D Adjust plug-in to create interlace patterns in the image. * Fixed an issue that could prevent the Auto Correct function in Stereoscopic 3D Adjust from working properly with source images requiring flips. * Fixed an issue that could cause removal of stabilization to could change the range of time represented by a subclip. * Fixed a crash that could occur when a string consisting entirely of unsupported characters was entered for a closed caption. * Fixed an issue reading HDV clips captured with certain third-party tools. * Fixed a hang that could occur when compositing or crossfading between large still image sequences. * Fixed alpha channel for PNG images rendered as an image sequence. * Fixed a problem rendering projects using 32-bit floating point video as image sequences. * Expanded scripting properties and methods for stereoscopic 3D and OFX plug-ins. Scripting changes have been posted to the Vegas Last edited by Mike Kujbida; December 22nd, 2010 at 12:00 PM. |
Still waiting for 64bit version...
All versions are now available.
OFX features in 1/3 of the changelog entries. Maybe I'm being cynical when I wonder if that smacks of a technology that was hastily incorporated ;-)
#5 |
The list of things they had to fix boggels the mind...I wouldn't want the job for a million bucks.
Thanks Sony!
"The horror of what I saw on the timeline cannot be described." |
#6 | |
I know a developer here, who nearly blew his brains out back at Version 8 .. I believe it was. Cheers.
Support your local movie theatre, they need it. |
#7 |
Hope it addrs that memory low issue. Still have it sometimes.. I have this weird issue of rendering black screens in parts of the video. Anyone has it?
Firewerkz Films SGP |
#8 |
I have a hunch that one of the less notable fixes was my issue with Vegas crashing too frequently whenever I switched through the File tab from one Vegas project to another. I brought this up here once or twice and no one else reflected upon it, so I just began filling a report every time that Sony popup asked for details after a crash. Well, so far no crashes and I've given it quite a workout; so thanks from me, Sony.
Paul |
