There HAS to be a simple answer....! at DVinfo.net
Old January 25th, 2011, 03:16 PM   #1
In the "Insert Generated Media" section, I am creating a credit roll on transparent to list names. One name has a French derivation and for the life of me, I cannot get an accent mark over the last "e" in the name. The best I can do is an apostrophe after the "e". Can someone give me a tip? Please?
Tracy Foust is offline   Reply With Quote
Old January 25th, 2011, 04:04 PM   #2
Just a guess here but can you spell it out properly with the right accent in MSWord? If so then simply cut and paste into the generated media.
Don
Old January 25th, 2011, 04:09 PM   #3
Do a search for the Windows Character Map facility in the Windows Accessories folder. I keep its icon on the desktop. You can generate and copy most accents and characters with it. Just copy and paste into the title generator.
TV Director / Cameraman
Old January 25th, 2011, 04:49 PM   #4
also depends on whether the font you are using has ė in it's character set.
Leslie Wand is offline   Reply With Quote
Old January 25th, 2011, 06:34 PM   #5
try holding the Alt Gr key when typing the e. Note that will only give you é, not with the accent the other way round (which is important).
This might also be of interest: Foreign Language Characters, Diacritics, Accent Marks, Computers, KeyBoard Help, kbh
Ian Stark is offline   Reply With Quote
Old January 25th, 2011, 09:13 PM   #6
è is certainly in arial....
Old January 26th, 2011, 12:29 AM   #7
Try it my way and you have ALL the accents and characters - that's what it's for.
Just simple copy and paste: it's a no-brainer...
I have to use accents for Welsh every day and wouldn't be without it.
Old January 26th, 2011, 12:32 AM   #8
hi robin,
that is, if it's in the font set.....
Old January 26th, 2011, 06:00 AM   #9
And the Oscar goes to............
Originally Posted by Robin Davies-Rollinson View Post
Do a search for the Windows Character Map facility in the Windows Accessories folder. I keep its icon on the desktop. You can generate and copy most accents and characters with it. Just copy and paste into the title generator. Try it my way and you have ALL the accents and characters - that's what it's for.
Robin, Thanks so much for the tip. On target because I have no brain!!
And thanks to ALL that chimed in on this:
Don Bloom
Leslie Ward
Ian Stark
Old January 26th, 2011, 10:55 AM   #10
Then you should add the Welsh keyboard from Control Panel / Region and Language / Keyboard and Languages / Change Keyboards. You can then switch between the English keyboard (or whatever you use as your primary keyboard layout) and the Welsh keyboard by pressing Alt-Shift. And you will never have to go through the copying the Welsh text from Character Map and pasting it to Vegas or any other program again. Of course you will have to remember which key now represents which letter, but you will learn that quickly.
Adam Stanislav is offline   Reply With Quote
Old January 26th, 2011, 11:07 AM   #11
Quite, Adam! That's an even bigger no-brainer for people that use a specific language's extended character sets regularly, rather than having to load Character Map all the time (not that that's a huge inconvenience, but if there's an easier way . . . .)
Maybe not for Tracy and the single é, though!
