Problem with velocity envelope. at DVinfo.net
Old January 27th, 2011, 11:33 AM   #1
Sometimes when using a velocity envelope a clip appears to quickly go in and out of focus repeatably. Any idea what causes this or a fix?
Paul Doss
Alabama Gulf Coast Video
www.algulfcoastvideo.com
Paul Doss is offline   Reply With Quote
Old January 27th, 2011, 12:03 PM   #2
Sponsor: JET DV
Is it only during preview? Or after a render? If it's during the preview, turn off the "Adjust size and quality for optimal playback" option.
Old January 27th, 2011, 01:15 PM   #3
Thank you Edward. It is after the render. But I can remove the envelope and render and it is fine. Doesn't do it all the time. Seems to be worse on pans.
Paul Doss
Old January 28th, 2011, 08:17 AM   #4
Sponsor: JET DV
It could be interlacing issues, then. Try changing the interlacing settings to different values until you find the setting you like best.
Old January 28th, 2011, 07:45 PM   #5
You did check "disable resample" on your video event?
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old January 28th, 2011, 10:16 PM   #6
Thanks guys. I'm out of town right now but will check on those things as so as I return home.
Paul Doss
