Architect re-compresses 24/192 stereo PCM at DVinfo.net
Old January 31st, 2011, 10:41 AM   #1
I'm trying to render blu-ray discs with audio (2 channel) that was recorded as 24/192 PCM. DVD Architect 5.2 says audio will be re-compressed even though there's plenty of disc space. Is there a workaround?
Duane Adam is offline   Reply With Quote
Old January 31st, 2011, 12:40 PM   #2
did you set the Audio defaults in your DVD-A project?
Go File > Properties, scroll half-way down to Audio defaults:
1) Audio format: PCM Stereo
2) BIt depth: 24
3) Sample Rate (Hz): 192,000
(i've never made a Blu-ray with 24-bit audio so don't know if this'll solve your problem)
Rob Wood is offline   Reply With Quote
Old January 31st, 2011, 01:33 PM   #3
Yeah that's how the properties are set up. Puzzling that it will let you select 24/192, and then automatically re-compress the sample rate.
Old January 31st, 2011, 01:45 PM   #4
It will let you select anything, but it must re-render if the settings you choose are not compliant with DVDA.
Go to Vegas help and you'll find the parameters for settings that do not have to be re-rendered.
Old January 31st, 2011, 11:07 PM   #5
Thanks guys. This is for blu-ray not DVD and 24/192 is a permissible bit and sample rate. The help dialogue confirms this. I rendered a few samples and the rendered file seems to be the same size as the original 24/192 files so I'm not sure the audio files are actually being compressed. They certainly aren't being reduced to 24/96 or 24/48, though I'm not sure they're being rendered untouched.
Old January 31st, 2011, 11:12 PM   #6
See what you mean now, that is weird, but as you point out it seems no loss of quality is occurring, so not much to do...will just cost you a bit extra time.
