Seeking advice selecting optimal render settings - for playback on my pc - Page 2 at DVinfo.net
Old May 3rd, 2011, 04:39 PM   #16
Re: Seeking advice selecting optimal render settings - for playback on my pc
Will do. Thanks Jeff.
Adi Head is offline   Reply With Quote
Old May 4th, 2011, 12:03 PM   #17
Hey Jeff.... getting back to the rendering...
selected the PAL DV widescreen template
selected .avi file format
clicked on the Video Format drop-down menu.... and couldn't find any codec with a = sign next to it.
this is what I see:
http://i53.tinypic.com/2hhzps1.jpg
Old May 4th, 2011, 12:41 PM   #18
Which version of Vegas are you using?
Old May 4th, 2011, 01:45 PM   #19
Vegas 9e
I think I see what you mean now....
I see the = near the PAL DV template... so should I use that?
By the way I made a couple of test renders using PAL DV and DivX. Both look pretty much the same, possibly the PAL DV version looks a bit better. The PAL DV file is much larger, but size doesn't matter much to me.
So would this be my best bet?
I was sure that DV compression is pretty harsh and since the source material is not DV, but rather mpeg2 from a DVD - that it wouldn't make any sense re-compressing it to DV.... or is that not what is happening?
Old May 4th, 2011, 02:10 PM   #20
The = sign means it is the best fit of the avi templates. I would use the one that looks best. I'm not sure what you mean exactly on the rest. avi files are very usable, and I would go with that if size is unimportant.
