Need help ASAP with audio problem at DVinfo.net
Old May 9th, 2011, 06:01 AM   #1
I shot a project at 24 frames per second and I need to burn it onto a DVD. I am editing in sony vegas pro 9.
I am having trouble with the audio sync when I try to play it in a DVD player. The words are slightly off. I assume this is because when I burn the dvd it becomes 30p (29.987). How can I get my audio to be lined up in sync on the DVD?
The only DVD burning software I have is Windows DVD Maker so I can not burn a 24p DVD using markers like you can in Arcitect.
Please help
Dave Brytus is offline   Reply With Quote
Old May 9th, 2011, 06:31 AM   #2
Re: Need help ASAP with audio problem
If you have Pro 9, you should have DVD Architect as it comes with Vegas.
It's a separate download but they do come together as a package.
Old May 9th, 2011, 09:39 AM   #3
I do not have archiect...I need another option soon
Old May 9th, 2011, 11:41 AM   #4
Hi Dave,
i personally always use Sony Architect however I have used Ulead program in the past before and it works just fine. Give it a try.
good luck
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old May 9th, 2011, 12:20 PM   #5
I'm still trying to figure out how it's possible to have Pro 9 and not have DVD Architect.
Mike Kujbida is offline   Reply
