Rendered 16x9 is 4:3 with people tall and thin... at DVinfo.net
Old July 7th, 2011, 09:08 AM   #1
Is there any way to fix this in DVDA or prior to insertion in DVDA without having to rerender the whole damn vid? (2.5 hours) :/
To clarify the footage is shot 16x9 and is supposed to be 16x9 but right now its all squished into a 4:3 box. :(
Working in VPro8 and it looks like it was just a stupid error on my part that rendered it thusly...although as I watched the beginning of it render it before I went to bed it looked 16x9 fine. :(
DVDA is set up for 16x9 video.
Any assistance would be greatly appreciated.
sincerely,
ian
Ian Slessor is offline   Reply With Quote
Old July 7th, 2011, 09:36 AM   #2
Re: Rendered 16x9 is 4:3 with people tall and thin...
Unless I'm mistaken, Ian, you seem to be thinking of fixing the footage by stretching it a different direction?
Just re-render it. It cannot be fixed.
Old July 7th, 2011, 09:53 AM   #3
Damn!
That's what I thought, Jeff, but I was holding out hope for an alternate option... :/
Thanks.
Now back the renderer-er..... heh.
*sigh*
ian
Old July 7th, 2011, 09:58 AM   #4
Good luck!
Old July 7th, 2011, 12:04 PM   #5
Jubal 28
What error did you make on render, and where are you seeing it as a squished 4:3 box?
David Jimerson is offline   Reply With Quote
Old July 7th, 2011, 04:22 PM   #6
Hey David,
The only thing I can think of is that I'd already rendered a similar video (day 1 of 3 days of recitals) and when I went to render day 2 the bitrate/aspect/progressive items were all set but then I stepped out of the setup for that for a moment (I'd never saved the settings...doh!) and went back into them noticing the bitrates had reset default so I re-entered the numbers, set to progressive but, perhaps, forgot to set 16x9 so it rendered out as 4:3.
grrrr.
Well, back to the comp.
ian
Old July 7th, 2011, 04:40 PM   #7
Jubal 28
But if you set it to render as 4:3, it should letterbox the footage, not squish it. (Unless you also messed with the "stretch to fit" settings or something, but that's probably not likely.)
I ask because it's possible there was nothing wrong with the render; it could be that whatever you're watching the footage in is simply displaying it as 4:3 instead of 16:9. If it does this with widescreen footage, it will appear as you describe.
Old July 7th, 2011, 05:36 PM   #8
Hmmm.
Well, I played it in VLC and Windows Media Player and it's squished.
David, I hear what you're saying about the black bars. Yeah it should show if rendered 4:3
So, maybe I did uncheck "stretch to fit" damn.
ian
Old July 7th, 2011, 06:12 PM   #9
Jubal 28
How does it look in DVD Architect?
Is this an AVI or MPEG file?
For DVD Architect, just use the DVD Architect templates under MPEG-2. Don't change anything. Then you never have to worry.
Old July 7th, 2011, 06:19 PM   #10
It's an mpeg file with ac3 audio
All my menus and intro files are 16x9 but when I preview the rendered video it is squished with bars on the sides.
And mpg2 templates?
Am I blind?
heh.
I'm using DVDA5
ian
Old July 7th, 2011, 09:22 PM   #11
Jubal 28
Yeah, then you need to re-render.
Old July 9th, 2011, 03:22 AM   #12
Yup.
And that's just what I did, Dave. :)
Thanks for the advice everyone.
Appreciated, even though I had to re-render. :)
sincerely,
ian
