GPU acceleration in Pro 11 - Page 6 at DVinfo.net
Old October 24th, 2011, 12:35 AM   #76
Re: GPU acceleration in Pro 11
hola,
eay question: would i notice this improvements on my Xp32 OS? I have a quadro fx3600 but running just XP32.....
many thanks
Old October 24th, 2011, 01:13 AM   #77
Vegas 11 doesn't support XP.
Old October 25th, 2011, 08:09 PM   #78
Hi guys. I've got a problem.
While rendering (usually at 3 or 4% of the project) the monitor blacks out and after a second or two it comes back up and windows says "Display driver crashed and recovered"
After that Vegas seems to continue render but it doesn't. It just stacks.
In order to render i had to un check the "enable cpu acceleration" tab.
Any ideas?
System
Asus Samertooth X58, i7 960, 24GBram, ATI Radeon 6790 1GB ddr5, catalyst driver 11.9
Win7 64, Vegas 11 64
Stefanos Lampridis is offline   Reply With Quote
Old October 25th, 2011, 09:16 PM   #79
Stefanos, you are lucky you can render at all. I cannot render 720p for Bluray even after unchecking GPU, and I have about 20 projects shot in 720p to do. I'm stuck with V10. Can't use 11 at all. I have to wait and see if the first update fixes the issue. It probably will, but who knows?
Old October 25th, 2011, 09:29 PM   #80
I found the problem, I was using a render template from V10, V11 doesn't like it. I made a new template in V11, runs great. Problem solved.
Old October 26th, 2011, 03:27 AM   #81
Thanks Jeff! I will try this and report back!
Old October 26th, 2011, 10:13 AM   #82
I'm doing some twixtor work and i gotta say V11 rocks! It is FAST. There are a lot of flexibility now that even CC wheels can be key framed. I do not like the new top to bottom 3 colour wheel but the keyframe option superb. This is truly quite a good upgrade
Firewerkz Films SGP
Old October 26th, 2011, 10:51 AM   #83
Unfortunately this does not solved MY problem, but it was worth a try.
I created a new template from scratch but nothing changed. At the 4-5% stage the display card driver crashed and rendering halted.
So any other thoughts anyone? :)
Old October 28th, 2011, 11:03 PM   #84
Originally Posted by Ho-Jong Wong View Post
Anybody having problems rendering with GPU acceleration but preview with GPU works fine? I'm using an ATI 5770 and the preview acceleration seems to work great, but as soon as I try to render MainConcept AVC/AAC I get the message "An error occurred while creating the media file ... The reason for the error could not be determined." If I change the encode mode to "Render using CPU only" the file renders fine. I am using Catalyst 11.9 drivers.
I thought only Sony AVC has support for GPU rendering - did that change with Pro 11???
Andreas Neubert is offline   Reply With Quote
Old October 29th, 2011, 07:22 AM   #85
Sponsor: JET DV
Andreas, there's LOTS of GPU changes in Vegas Pro 11!
Old October 29th, 2011, 09:38 PM   #86
Originally Posted by Sean Seah View Post
...I do not like the new top to bottom 3 colour wheel but...
If you click the custom tab on the color corrector you get the old horizontal 3 color wheel.
Bill Koehler is offline   Reply
