Rendering as QuickTime at DVinfo.net
Old October 28th, 2011, 10:58 PM   #1
I have an HD project on the time line with settings - HDV / upper field first / par 1.3333 (HDV 1080) and have no problem rendering to HDV or Mpeg-2. (Veg Pro 9).
However, when I render to QT, instead of it taking a few minutes for the render box to complete (100%) it jumps to 100% and the resulting file is only 1Kb and hence won't play. How do I make a high quality QuickTime file that will play ?
Any suggestions ?
RonC.
Ron Cooper is offline   Reply With Quote
Old October 28th, 2011, 11:35 PM   #2
Re: Rendering as QuickTime
what version vegas / what version quicktime?
www.lesliewand.com.au
Leslie Wand is offline   Reply With Quote
Old October 29th, 2011, 12:32 AM   #3
Vegas Pro 9 as mentioned, to QT7. This is the only one listed in the Vegas menu.
RonC
Old October 29th, 2011, 03:01 AM   #4
sorry...
what version of quicktime do you have installed?
apparently you need 7.6.2, no later otherwise you'll have problems in vegas.
Old October 29th, 2011, 06:34 AM   #5
Thanks Leslie, - trap for the unwary it seems. I downloaded the latest QT last week but when I open the player and go to properties I cannot see any version reference. How do you determine the version ?
Obviously it will be the latest version so I suppose it will be later than what Vegas wants to use.
Ron C
Old October 29th, 2011, 07:25 AM   #6
Sponsor: JET DV
If you downloaded the current version last week, it is certainly NOT 7.6.2.
Old October 30th, 2011, 05:00 AM   #7
I uninstalled QT, re-installed Vers. 7.6.2 re-booted and tried again but I still get the same result.
When I try to play this "rendered ??" file, I get :
Error - 2000: a necessary data reference could not be resolved (file name).mov.sfl
Any further suggestions ?
RonC
Old October 30th, 2011, 01:48 PM   #8
This may be a corrupt sfl file, perhaps something to do with your previous version of QT. Try deleting it or archiving it elsewhere - Vegas should create a new one...
Old October 30th, 2011, 08:47 PM   #9
Thanks Seth, I will try this but I don't follow why it does not create a big file in the first place - (even a corrupted one !), as it simply shows a 100% render, instantly.
RonC.
Old October 31st, 2011, 04:53 AM   #10
Further to my last reply I now realise that I had to uninstall the previous version of QT before I could install v. 7.6.2. Once I did this I then re-booted to make sure that the older version should then install OK.
RonC.
Old October 31st, 2011, 07:14 AM   #11
Sponsor: JET DV
Uncheck the "Include Markers" box.
Old November 1st, 2011, 04:58 AM   #12
Thanks Edward, but unfortuneately it made no difference.
RonC.
