Mixing progressive and interlaced
Hello,
I was wondering if someone might be able to give me some pointers with something that's got me about to tear my hair out. I realize that I'm using an awkward mix of equipment here but it's all I've got at the moment and I'd like to think that I could get an acceptable final result with what I have. I'm much more of an audio person so please be gentle with me if I phrase things incorrectly here... I've got some live music footage captured on two cameras: -Sanyo Xacti HD200: MP4 - 1920x1080i - 29.97fps, upper field first -Panasonic ZS-3 (point&shoot camera): m2ts - 1280x720p - 29.97fps As I understand it, the ZS-3 incorrectly flags its output as 59.94fps. Another possibly confounding factor is that I'm in the UK with UK equipment but I don't seem to have had problems playing back NTSC stuff in the past. I'm replacing the camera audio with a separate 48khz 24bit track. And I'm using Vegas Platinum v11. I've synced up the footage and audio and have made my edits (by chopping out the bits of the ZS-3 footage that I don't want; the Sanyo footage is intact all along the timeline.) I have a few questions: -do the "project settings" have any influence at all, or do the render setting trump them? -what do you think the best format and settings are for rendering this project to a blu ray disc, bearing in mind that I'd like to keep the audio as uncompressed as possible? -is the ZS-3's faulty framerate flag going to cause problems here? -should I keep everything NTSC or convert to PAL? A slightly separate issue is that I wanted to make an SD version of these clips but every time I render to MPEG-2, I get blips in the video and audio. This doesn't seem to happen if I render to different formats. Weirdly, when I upped one of the clips to Youtube the glitch magically disappeared after a couple of days... This is only really a "practice project" designed to reveal potential issues but I'd really like to salvage something reasonable from the footage I've got. There are some Youtube clips here: Richmond Fontaine - Moving Back Home #2, Manchester 15 Sept 2011 - YouTube Richmond Fontaine - 1968, Manchester 15 Sept 2011 - YouTube Richmond Fontaine - Post to Wire, Manchester 15 Sept 2011 - YouTube Any advice anyone might be able to offer, even if it's just pointers to tutorials or past posts. |
Re: Mixing progressive and interlaced
Which do you have more of? About the same of each?
If I were going to make a blanket statement, I'd do it all (project and Blu-ray output) as 1080/60i. Unless you want the 1080/60i motion to match the 720/30p motion, in which case I'd edit as 720/30p and render that way, then do a re-render as 1080 for Blu-ray. -do the "project settings" have any influence at all, or do the render setting trump them? Project settings have plenty of influence, but render settings will trump them. -is the ZS-3's faulty framerate flag going to cause problems here? Not likely. -should I keep everything NTSC or convert to PAL? I'd keep it NTSC; it will preserve the best quality. |
Excellent - many thanks for that.
In terms of the balance of footage, the 720p is basically just close ups, probably accounting for less than 25% of the total running time. Two final questions for you: am I right in thinking that the "Blu-ray 1920x1080-60i, 25 Mbps video stream" is the one I want, giving an .m2v file as the output? And if so, how do I get the uncompressed audio in there? When I go to customise the template and click on the audio tab, it looks like I've only got compressed options. Do I need to render the audio separately? Thanks again. |
1 Attachment(s)
Assuming you plan to deliver your renders to the web (i.e. YouTube, Vimeo, etc.). Here's what I'd do. There may be better ways, but here's the test I just ran seems to work pretty well.
1) Create a Vegas Project using the "Match Media Settings" wizard to match the 720p source. 2) Add a 720p source clip to the timeline. 3) Add a 1080i souce clip to the timeline. 4) Add the yohng.com Yadif Deinterlace for Sony Vegas deinterlace FX as a Media FX 5) Render the project to the MainConcept "Internet HD 720p" template. The video is here: Mixed720p1080i.mp4 - YouTube However, the telling result is in the attached image. ...Jerry |
Many thanks for that - I've downloaded the filter and will give it a go.
| All times are GMT -6. The time now is 07:52 AM. |
