DVD looks awful after resizing from 1080i to SD in Vegas11 - Page 2 at DVinfo.net
Old January 29th, 2012, 09:59 PM   #16
Jubal 28
Re: DVD looks awful after resizing from 1080i to SD in Vegas11
Then it doesn't sound like you're describing an "interlacing" problem. Is there any way you can post any examples of the problems you're seeing?
David Jimerson is offline   Reply With Quote
Old January 30th, 2012, 06:22 AM   #17
It looks good on computer but not when you play it on TV.
I tried to upload it but still too big (only few seconds)
Michael Ojjeh is offline   Reply With Quote
Old January 30th, 2012, 06:41 AM   #18
Michael, open an account at Dropbox which allows you to upload and share any kind of data.
You get 2 GB. of storage space which should be more than enough for a few seconds of video.
https://www.dropbox.com
Old January 30th, 2012, 07:45 AM   #19
Originally Posted by Michael Ojjeh View Post
I tried the trial version of TMPGenc I didn't see that much different from Vegas.
What source file did you give TMPGenc ? I can always see I big difference in sharpness of edges and detail in coloured areas especially when the DVD is played back from an upscaling player. As Mike says export a small piece of the worst part of the timeline.
Ron Evans
Old January 30th, 2012, 09:27 PM   #20
I post the video on Vimeo, password dvinfo, you can download the source video.
Old January 30th, 2012, 09:35 PM   #21
last year same cameras same setting ( Vegas 9 ) the DVD looked as good as the HD version.
Old January 30th, 2012, 11:59 PM   #22
The scan order flags indicate bottom field first for the entire video, however, the field dominance actually changes about half way through from bottom field first to top field first. Most computer video players throw away every other field so reversed field dominance doesn't make any difference. A real DVD player doesn't do this and the reversed field dominance results in motion artifacts.
You could deinterlace the entire video to 30p and move on to the next project, or figure out why the field dominance switches back and forth between different clips and fix the video properly.
Eric Olson is offline   Reply With Quote
Old January 31st, 2012, 10:29 PM   #23
Just saw this thread; don't know if I can help but my 2c worth:
From my experience digital video (from tape etc) is always Lower Field First. Video from HD sources, including HDD, SD cards is Upper Field First.
Whichever field comes first doesn't seem to matter a damn; the golden rule is DON'T CHANGE THE FIELD ORDER. Rendering it as Lower Field First will do serious things to it from the get-go.
Why not try processing the whole thing, from start to finish, including the DVD, as Upper Field First?
Best of luck
Ron Windeyer is offline   Reply With Quote
Old February 1st, 2012, 10:54 AM   #24
Best of luck
The XHA1 is top field first. I agree that rending the whole video over as top field first may solve it.
