-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   Illustrator files into Vegas (https://www.dvinfo.net/forum/what-happens-vegas/506399-illustrator-files-into-vegas.html)
Renton Maclachlan August 20th, 2012 02:00 PM
Re: Illustrator files into Vegas
Originally Posted by Steven Reid (Post 1749180)
Just a quick check, Renton, since I've lost track of your stable of software: did you ever purchase After Effects? I ask because it's a shame (and incredibly laborious) to have to export 80 images for further manipulation, when you could drop a single 80-layer AI file in After Effects and be off to the races lickety-split.-Steve
Thanks Steve.
I've now got a good stable of software but the version of CS6 I have does not have AE...so I don't have it. I'm feeling somewhat swamped as to how to integrate what I have without having to learn another program.
I don't think it would be too laborious to do what I propose. Not each talk requires every layer so as I'm working each segment there would only be a few layers used. (I put each element into its own layer so it could be used and manipulated independent of all others.)
One 'disappointment' I have is that it appears that I will need to render out my green screen videos with their backgrounds, which means I won't be able to put my graphics between me as the presenter and the background, rather will have to put it over the video track. I'll just have to make sure as I move around, that the graphics are always clear of me. Having four tracks of Green Screen FX (four camera angles) slows up play back so I can't make precise cuts etc, even with my new computer. Or...perhaps I render out most of it, except those parts where I would like the graphic behind me. That would reduce the work the computer has to do. Perhaps I need to do my multicamera track and decide which clips require the graphic behind me and deal with that separately.
Renton Maclachlan December 10th, 2014 01:57 AM
Just opening up this thread again after a couple of years (for the possible interest of those who so helpfully contributed to it) in which I've produced the first four of 13 episodes of the project referred to above.
As it turned out the Illustrator file referred to in the thread was not used in the episodes already produced so I was premature in exploring the options for bringing into Vegas back in 2012. However I am now right at the stage it will be used so am now revisiting the whole issue and trying to make sense of the thread so far...and remember what I did back then. I may post up what I find the best/most acceptable way to do it...
I am aiming to move the project along a bit quicker through committing at least a day a week to it...
