Interlacing 25p to 50i in Vegas 10 - Page 2 at DVinfo.net
Old June 20th, 2012, 03:16 PM   #16
Re: Interlacing 25p to 50i in Vegas 10
Some of the responses are correct. One cannot get true 50i from 25p. The best that you can do, in this case, is for the software to "interlace" 25p using the PSF (Progressive Segmented Frame) method where alternate lines in the frame get bunched as one field and the remaining lines in that same frame get bunched as the second field (remember, two fields equals one frame). The client wants it that way because either that client's broadcast system only does interlaced or the client is using it for a Blu-ray authoring project whose frame rate cannot be slowed down (Blu-ray does not support 25p at all without interlacing via PSF).
Randall Leong is offline   Reply
