HELP!!! Vegas won't open my master project
Hello,
I spent about 10 hours yesterday working on a project. Today, when I went to open this project, I got the following error: "The file is most likely corrupted or of an unknown format." I tried renaming the .bak file but still could not open my project. I've never had this happen to me before. The only thing I did differently was load a trial version of Magic Bullet, which I used for the first time yesterday. Could this be what's causing the error message? And if so, how do I get around this and open my project? Thanks, Jerry |
Re: HELP!!! Vegas won't open my master project
For this very reason I will save several backups with different names as a day progresses. It just seems safe.
First, make a copy of the .veg file under another name just for safe keeping. Try to open that, and see if it is some kind of naming issue. Then I would uninstall Magic Bullet, and try again. If that doesn't work, then check out your Windows back up and revert the system back to backup prior to the installation of Magic Bullet. Try opening again. If that doesn't work try uninstalling Vegas, then reinstalling it.
Chris J. Barcellos |
My partner recently had the exact same thing happen with a Vegas Pro 11 project. We never were able to get it to work.
We are now going to start making two copies of each project also with the second one even being on a different hard drive. |
I write, direct and shoot our stuff and now have another team to edit. One of the first things I told 'em exactly what Chris and DJ say ..
'save a copy under another name on a different hard drive'. It's gotta become second nature, comes under 'housekeeping' Cheers.
Support your local movie theatre, they need it. |
#5 |
Sponsor: JET DV
Won't help for the past but for future reference, if you install Excalibur you can turn on Auto Save which will save your project every "x" minutes under a new file name so you have a series of backup files.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#6 |
I guess this is a lesson learned the hard way. However, this makes me a bit leary to purchase Magic Bullet, as this was just the "trial" version I was using. I don't know for certain that's what caused this problem, but I've never had this happen to me before.
To clarify, when I save my project file to another hard drive, I just need to "save as" under a different name. I do not need to copy the source clips, correct? Obviously, I already have all my clips saved on a second, back-up drive, but I assume I don't need to keep saving the media multiple times when I'm re-saving the project, correct? This would start to fill up hard drives very quickly... Thanks again for everyone's feedback. I'm just bummed that someone doesn't have a "quick-fix" for me to recover my work. ;) |
#7 | |
if the error happened on Vegas 10 try to download eval of 11 and open it, but if you make it work you'll need to finish your editing within the trial period, or buy ver.11, best
I love this place! |
#8 |
Buba is correct. No matter where you save the project file, it refers to the primary file locationa as far as looking for your project media files as you continue your edit.
#9 | |
Did you by any chance get the problem after installing the MB update mentioned here: http://www.dvinfo.net/forum/what-hap...ta-update.html. D |
#10 |
No, this was caused after I downloaded the "trial" version of Magic Bullet Looks 2.0. I'm not sure this is what caused the problem, but I've never had a problem like this, before I loaded this software.
#11 |
OK, good to know.
D |
