How hard would it be? at DVinfo.net
Old January 20th, 2013, 10:07 PM   #1
From a software point of view, hacking, whatever....
To be able to use the Burn to disc option in tools menu and,
1. include Markers as chapter points, Not menu related, just step through the video.
2. for us Pal users, it automatically creates a lower field first mpg, even if you have progressive video.
Can I open up some Vegas files in Notepad and change these things, or is it just to hard?
Never know if you don't ask
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old January 21st, 2013, 03:58 PM   #2
Sponsor: JET DV
Re: How hard would it be?
#1 - not sure of a way to specify this.
#2 - I did not see any progressive options for PAL. I did for NTSC, though. I tried creating a preset but that did not change the list shown.
It's really easy to go a quick render to MPEG2 and then just load that in DVD Architect and do a "Single Movie" there which is essentially the same thing. It might take just a little bit longer but then you'd get what you want.
Old January 22nd, 2013, 04:40 AM   #3
Thanks for trying Edward.
Looks like Ill have to persist with Architect.
The cursed program is like Kryptonite to me, I get in there and start clicking around and going nowhere, mess it up and run away like a scared little newb.
Anyone know any good links to Architect tutorials?
Id like to get a bit proficient with it.
Old January 22nd, 2013, 11:58 AM   #4
Architect has built-in interactive tutorials.
Juris Lielpeteris is offline   Reply With Quote
Old January 22nd, 2013, 01:56 PM   #5
Sponsor: JET DV
You can also look through the newsletters on my website. They will show you the basics of how to create a DVD in Architect.
Old January 23rd, 2013, 04:10 AM   #6
Interlaced or progressive is determined by the picture coding extension flags in the mpeg2 program stream files. The program dgpulldown with the setting Custom 25->25 can set this flag to progressive. I've not tried this directly with the VOB files in a DVD catalog, but it might work. If not, try running the command on the input files to DVD Architect before mastering the image.
DGPulldown
Eric Olson is offline   Reply
