Canon C300 and C100 Files into Vegas PRo at DVinfo.net
Old February 20th, 2013, 07:23 PM   #1
How do you convert/transcode c100 and c300 footage to play/edit in Sony Vegas Pro?
Canon DSLR's, C100, C300. FCPX, Sony Vegas Pro. Assorted Nikon, Canon, Zeiss lens.
Thomas Roberts is offline   Reply With Quote
Old February 21st, 2013, 03:34 AM   #2
Re: Canon C300 and C100 Files into Vegas PRo
You should be able to use the clips from those cameras directly on the Vegas Pro timeline...
No need to convert before editing...
Kim Olsson is offline   Reply With Quote
Old February 21st, 2013, 04:05 AM   #3
Sorry! I might gave you wrong answer..
Transfer/Import Canon EOS C300 1080i MXF to Sony Vegas Pro
Old February 21st, 2013, 07:09 AM   #4
Use the export function in the Canon XF utility. It will move all the mxf into one folder for easy editing within Vegas. You have to do it from the original card. If you forgot to then you will have to access one mxf in every folder!
Canon U.S.A. : Professional Imaging Products : EOS C300
Firewerkz Films SGP
Old February 28th, 2013, 11:12 PM   #5
Export is the way to go. You get to rename and add sequential numbering to each clip. Makes for a much more useable file system for future reference. No duplicate file names. Each clip can relate to your project.
i.e. 2013_Foobar_cam1_001
I can't imagine it getting any easier.
Write to your RAID 1 array, copy the file structure when done to a USB3.0 drive and take to your local offsite storage. Done.
Al Bergstein is offline   Reply
