can someone explain this... at DVinfo.net
Old March 6th, 2013, 03:52 AM   #1
In project Properties we can set 8 bit, 32 bit float video levels or 32 bit float full range.
In comp properties in After Effects I can choose 8 bits, 16 bits and 32 bits per channel.
Is this the same thing?
If so, why dont we have 16 bits per channel in Vegas?
Also, in After Effects if I use Neat Video plug in a 16 bit comp, Neat video works as a 16 bit plug in stated in the Neat video options window (see below)
But in Vegas, even in a 32 bit comp it only operates as an 8 bit plug in.( see other pic).
Explanations most appreciated.
can someone explain this...-afx-neat.jpg   can someone explain this...-vegas-neat.jpg
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old March 6th, 2013, 11:04 AM   #2
Sponsor: JET DV
Re: can someone explain this...
It could simply be that Neat does not support Vegas' 32-bit mode. You'd need to ask Neat that question.
Edward Troxel is offline   Reply
