DVD Architect & Menus... - Page 2 at DVinfo.net
Old February 14th, 2007, 01:18 PM   #16
Originally Posted by Edward Troxel
When editing in Vegas, render the entire project out as one single file.
how will you be able to skip through scenes on the dvd then?
Joel Bradley is offline   Reply With Quote
Old February 14th, 2007, 01:56 PM   #17
Joel, if you set markers in either Vegas or DVDA, they become chapter points that you can skip to using the next/previous buttons on your player's remote.
Old February 14th, 2007, 07:50 PM   #18
Thank you!
Old February 15th, 2007, 01:56 PM   #19
Originally Posted by Dave Stern
This does look related, although my problem was specifically with the menu structure. I could get the media files to play, however I have just downloaded the PGCEdit tool, and I will report back if this cures the problem. Of course, I have now also upgraded to the latest Vegas /DVDA as well.
Declan Smith is offline   Reply With Quote
Old February 15th, 2007, 05:55 PM   #20
100% Solved Issue (well workaround)
Thanks to this superb forum I can finally throw away ULEAD and create DVD's using DVDA that work totally as I expect.
The solution provided here (referenced from other post) http://www.sonymediasoftware.com/for...ssageID=500341
has totally fixed the problem. I recommend using the pgcedit tool to finally prepare what DVDA spues out and then use nero as explained to burn the DVD.
I ran a project through DVDA 4.0 and burned as is via nero, the problem with the menus was apparent and disc error was displayed. Then I took the DVDA output and ran it through PGCedit and again burned it using nero. This DVD worked a treat.
The tool can be downloaded from http://download.videohelp.com/r0lZ/p...dit_winexe.zip
The only problem I have now is that my source of DVD beer mats will be reduced somewhat!
I had reported this problem to Sony when it was DVDA 3 and they provided no solution, so thanks again to this great community.
Old June 25th, 2007, 11:30 AM   #21
Try to use chapter markers rather than individual clips.... you can also use the chapter markers to simulate individual clips rather than havng lots of clips on the dvd Just a thought
Martin Smith is offline   Reply
