vegas 6 plus HD100 for capturing dv footage at DVinfo.net
Old December 28th, 2006, 04:46 PM   #1
I've been trying to use my HD100 as a passthrough deck for capturing a dvd into vegas. No luck so far. Although Vegas is doing a fantastic job of seeing my webcam...
At any rate, does the hd100 even have this capability?
I've got the analog outs of my dvd player going into the JVC hd100 and firewire connecting the hd100 to the computer/vegas 6.o. HD100 set to "VTR" and "DV". DVD set to "play". So far just a black screen.
any ideas?
Old December 28th, 2006, 07:06 PM   #2
Brian,
I am using Vegas 7 now and can't remember if 6 would, but you can go to:
File>Import>DVD Camcorder Disc...
and 7 will pull the video off of a DVD in your pc DVD drive. I have only tried this on home DVD recordings, and not copy protected stuff. It works on recordings from my DVD recorder deck, and DVDs I have authored.
Edit: I have a Sony TRV-22 camcorder which has pass-through. If I recall correctly, you have to set that function to "on" in the menu system of the camera.
Jamie
Jamie Hellmich is offline   Reply With Quote
Old December 28th, 2006, 07:33 PM   #3
Originally Posted by Jamie Hellmich
Brian,
Jamie
I've got file>import but nothing specific for DVD after that...
Old December 28th, 2006, 08:19 PM   #4
Do you not have a DVD drive on your computer?
It's much easier than the way you're trying to do it.
BTW, the File>Import>DVD Camcorder Disc feature was added in Vegas 6.0c and 6.0d was the final version of 6.0.
Old December 28th, 2006, 08:44 PM   #5
AH okay. I'm using 6.0a. I'll try and upgrade.
It's still worth knowing how to use an hd100 as a passthrough. Old vhs tapes etc.
Old December 29th, 2006, 10:37 AM   #6
Encryption
Would the PC method still work with an encrypted commercial movie? I somehow doubt that, but I could be wrong.
jason
Jason Robinson is offline   Reply With Quote
Old December 29th, 2006, 02:17 PM   #7
Brian,
I just looked through the HD100 manual and it looks like you'd have to record from a DVD player with firewire to the camera and record it on tape, then transfer it. The camera doesn't appear to allow an analog signal in, only firewire.
I believe how to do it was on page 57 of the manual I was looking at.
Jamie
Old December 29th, 2006, 02:22 PM   #8
Brian,
Jamie
What started me on this oddysey was Ed Troxyl's outstanding webpage (www.jetdv.com) which suggests a deck passthrough as the best means of capturing dvd footage into vegas. But it seems this file>import>dvd might be the simpler solution.
Thanks for the info.
brian
Old December 29th, 2006, 02:32 PM   #9
File>Import>DVD works great for me.
Jamie
Old December 29th, 2006, 03:11 PM   #10
Jamie
What are the limitations of this feature? the HELP menu doesn't say much about it other than it's supposedly for the sony dvd disk cameras.
Old December 29th, 2006, 07:30 PM   #11
Even though it says it's for miniDVD discs, it'll work on regular discs as well.
The only hitch is that it does take some time to import an hour (or more) long disc.
BTW, the discs have to be copyright-free (i.e. non-commercial) or this feature won't work.
Mike Kujbida is offline   Reply
