dvd architect 3.0 problem... at DVinfo.net
Old January 7th, 2007, 05:30 AM   #1
I'm unable to burn to dvd with my vegas 6 project in in dvd Architect 3. I go to make DVD and start going through the steps but it won't proceed after the message "not enought space in temp files folder." It also says I will be compressing files. I tried a disk clean up utility and restarting it but the "next" button won't turn on. what can it be?
Old January 7th, 2007, 06:49 AM   #2
Options - Prefs - Burning - Temporary files folder.
Is it set to the default directory? I change mine to a separate render drive where I know I will always have lots of space.
BTW, I do this in Vegas as well.
As far as compressing files, DVDA usually does this when either you've fed it a non-compliant file (eg. wav instead of AC-3) or a file that's too large and has to be compressed to fit. How long was the video and what render options did you use from Vegas?
Old January 7th, 2007, 07:03 AM   #3
Sorry to but in line here, but Mike just desccribed my problem with DVDA 3.0 What is the right type of audio file to render to for DVDA 3.0
And you mentioned how you "do it in Vegas as well" referenceing the temp file folder option. What is the advantage to that?
I guess what I mean is could you explain why you do what you do if you have time? OR where I could find these basic setup answers for DVDA 3
Bradley D Barber is offline   Reply With Quote
Old January 7th, 2007, 07:13 AM   #4
First AC3 is DVDAs prefered audio type. You might just as well render your Vegas project to AC3 in th efirst place and be done with it. If you are using the "lite" version of DVDA (Movie Studio) then it will not allow you to render to AC3 in the editing portion of the program but will in the DVDA portion.
As for resetting your temp folders- IMO the worst thing you can do is to have TEMP or CAPTURE folders on your system drive. Set thoses folders on another drive so IF or WHEN the system crashes you haven't lost those files AND since capture consumes a lot of drive space why clog up the whole system by having those files on the system drive.
Just point the computer to another drive and be done with it.
If you render to AC3 in Vegas read Edward Ts newletters about the settings to use for the render to maintain a volume level thruout.
Don
Old January 7th, 2007, 09:58 AM   #5
Don, thanks for doing a great job of explaining things. It's amazing how many problems occur because people don't bother (or don't know how) to change the default folder paths.
As far as AC3 audio, it's only a preference because, once again, it's the default. DVDA can (and I know several folks who do it) use PCM (i.e. wave files) because it's not compressed like AC3 is.
For those of you don't know or realize it, AC3 is like MP3. By that, I mean it's a highly compressed format (approx. 10:1 over the original). Using it allows you to fit more onto a DVD or to bump up the bitrate if you want to and that's why most of us use it.
Mike Kujbida is offline   Reply
