-   What Happens in Vegas... (https://www.dvinfo.net/forum/what-happens-vegas/)
-   -   How to edit an action scene... (https://www.dvinfo.net/forum/what-happens-vegas/83682-how-edit-action-scene.html)
Steven Bills January 11th, 2007 04:24 PM
It snowed today, so we did a chase on some snowmobiles and motorcycles. I have a lot of footage, and I have many angles of the same shot and I was wondering what the best way to edit it was, and what I need to do in order to keep up the intensity.
SB
Don Bloom January 11th, 2007 05:02 PM
You said you have many angles of the same action sequence-If that means you had more than 1 camera running I would drop all the footage of those sequences on to seperate tracks, PAN/CROP them to fit on the preview screen(set to 1440X and move them over and up or down as needed to get all onto the screen) find a sync point and run it. Set markers t oindicate where you want to make the cuts-make 'em and move those clips UP to a MASTER track-remove the PAN/CROP from those clips and continue with your edit-FXs Color Correction whatever. I would certainly use CUTS not disolves.
Of course if you have Excalibur OR Ultimatte S the multicam editing is a whole lot easier.
Don
Steven Bills January 12th, 2007 10:51 AM
Thanks for the advice Don.
SB
Jason Robinson January 12th, 2007 11:18 AM
free plugin
SB
VASST does have a free 2 camera script that you could use twice.... choose between 2 angles and them do that with the other 2 and then choose between the 2 master cuts. Takes a lot more planing because you haveto know what you want to do on tracks 3&4 while you are working on 1&2.
jason
Brian Luce January 16th, 2007 12:07 PM
Were it me, I'd probably get frame grabs from every shot and perhaps print them out. Then I'd pin them on a bulletin board and create a story board. No more than 5 seconds per shot.
I'm old school I guess.
