Render Time at DVinfo.net
Old February 8th, 2007, 05:09 PM   #1
Render Time
A recently finished an 11 minute documentary. It took me 18 hours to render. That to me seems like a very long time. It may very well be my computer (laptop) at fault. Here are the specs.
Processor
* Processor manufacturer
* Intel
* Processor type
* Pentium M
* Clock speed
* 1.5 GHz
* Core voltage technology
* Ultra Low Voltage (ULV)
Mainboard
* Chipset type
* Intel 855GM
* Data bus speed
* 400 MHz
RAM
* RAM installed size
* 512 MB
* Max supported RAM
* 2 GB
* RAM Technology
* SDRAM-266 MHz
* Memory specification compliance
* DDR266/PC2100
Display (Projector)
* Display (projector) diagonal size
* 14 in
* Display (projector) technology
* TFT active matrix
* Color support
* 16M colors
* Max resolution
* 1280 x 768
Video Output
* Graphics processor
* Intel 855GM
Video Memory
* Video memory technology
* Shared video memory (UMA)
Storage Hard Drive
* Hard drive
* 80 GB IDE Internal
Any input on why this took so long and how to avoid this in the future would be great.
Steven Julien is offline   Reply With Quote
Old February 8th, 2007, 05:48 PM   #2
First what did you render to, MPEG, AVI or???
Second, what video FX if any did you have going on the clip(s) you were rendering.
Certain effects will just suck up all the juice from the computer and make it run like it's filled with maple syrup.
Some more info would be helpful.
Don
Old February 8th, 2007, 06:04 PM   #3
My initial guess is that your computer is running out of RAM and using the disk as "extra memory".
Try a second render and hit Control-Alt-Delete key simultaneously to bring up the Windows Task Manager. Click on the Performance tab. During render, watch the CPU meter as well as the RAM usage. If your Available Physical Memory drops to below 50,000K, you're limited by your system RAM.
Beyond the project content and effect reductions Don asked for, you can only hope to change a handful of items in your notebook:
Here are a few hardware upgrades:
1) Upgrade RAM to at least 1 GByte for WindowsXP
2) Add 2nd disk for project files
5) Upgrade your hard drive to a faster, larger unit, such as a 5400 or 7200 RPM, which will help a bit if you have one of those slower 4200 RPM drives
Here are a few manual upgrades :
1) Defragment your main drive
2) Keep your disk drives less than half full for greater performance
3) Check your output video file type. If you're using a time consuming process such as two pass Variable Bit Rate (VBR), try switching to Constant Bit Rate (CBR).
Gints Klimanis is offline   Reply With Quote
Old February 8th, 2007, 06:18 PM   #4
I'll start off with Don's question first then i'll work on what Gints recommended.
The majority of the effects were magic bullet filters. I was also heavy on correcting audio through an audio editor. Thats pretty much it for that.
Now I'll take a closer look at your reply Gints.
Old February 8th, 2007, 06:26 PM   #5
OK Gints. The average APM is 56000-58000 and it does drop down below 50000. I saw it go as low as 30000. Also my CPU is certainly maxed out at 100. I do have a newer external 250gb HD. I'll work on getting the extra ram and the defraging. I am not clear on the VBR and CBR. I am rendering another project right now 3minutes and its taking forever as well. As soon as that is done I will look into what the setting is at.
Old February 8th, 2007, 06:46 PM   #6
The use of Magic Bullet FX can increase render times by as much as 10x :-(
Old February 8th, 2007, 07:00 PM   #7
problem= 1.5 ghz cpu, plus magic bullet + other filters / fx
Dave Stern is offline   Reply With Quote
Old February 8th, 2007, 07:20 PM   #8
yep, MB is an absolute KILLER on renders.
IF you're going right to MPEG and it sounds like you are why not try this. Rneder to AV FIRSTTHEN goto MPEG-it won't take as long to render to AVI and then it won't take as long to render that to MPEG. It sounds goofy but I do that a lot and it is faster. The AVI render might take a couple of hours but once you've got the AVI with all of the effects imbedded it should go to MPEG fairly quickly. 18 hours? Man I do not have the patience for that AT ALL-especially an 11 minute project (ask my wife - she'll back me on that one)
Don
Old February 8th, 2007, 07:33 PM   #9
Great replies and thanks everybody for your input. I am now on a quest to ditch magic bullet and not be lazy about color correction. I learned a great tip today using sony vegas color correction. Yeah, 18 hours was just stupid but my laptop isn't all that so I will do with what I have for the time. Thanks again.
Old February 8th, 2007, 07:56 PM   #10
Processor
The Pentium M is a horribly crippled version of whatever generation of chip you could have been using. That chip is just not meant for multimedia applications like this. Spreadsheets? Sure. Surf the web? No prob. They were designed for mobile applications where power consumption is at a premium so performance is skimped. Here is why.
All processors have "cache" memory and instruction memory that is located inside of the CPU itself. when a program is running, the set of instructions to run is loaded by the program counter to the instruction cache as short "ToDo" list. then when an instruction need to do something, it asks the cache memory if it has that bit of data. If not, the CPU pauses whatever it is doing, and then requests that data from main memory which is alllllllll the way back off the CPU, down the bus to the memory controller, back out another bus to the RAM dimm, back the same bus, through the memory controller, and back to the cache memory. Only then can the program counter pass the completed statement to the execution unit which figures out how to do what that instruction wanted to do.
The problem with the Pentium M is that CPU is crippled by an extremely small memory cache (unless it is one of the latest generations of the M chip name). so almost anything involving lots and lots of data (like encoding) that is always changing (each frame / is different) means the CPU is sitting there in a busy wait state waiting on data from main memory.
So even though you have 2GB of RAM, the on die cache is the main limiting factor for applications that always need new information in the cache. The M series have only 1024KiB (1MB) while most Core 2 Duo chips have 2MB or 4MB for the latest and greatest. This doesn't sound like much memory, but consider that cache is sometimes a bigger reason for a performance boost. The down sides is that a CPU chip is an extremely expensive piece of real estate for a space hog like memory. That is why chips with lots of cache memory are very expensive (large die surface area means greater chance of manufacturing defect & less % yield & higher fabrication costs).
hope that helps some. Here is a good article.
jason
Jason Robinson is offline   Reply With Quote
Old February 8th, 2007, 08:25 PM   #11
Try 25x if using more than one filter on the same clip...
"The majority of the effects were magic bullet filters"
for ur GFX card, u wotn get any performance boost from MB2.. but if u had Nvidia, youd be able to render this faster than realtime..
Peter Jefferson is offline   Reply With Quote
Old February 8th, 2007, 08:32 PM   #12
OK, well heres teh beauty of Vegas filters.. theyre FAST... and wit teh rigth combination, you can easily get manyu MB "lookss" happening withotu the fitler..
In the past when MB first came out, i really REALLY got sick of teh stupid render times, so i went through certain "looks" which i liked and created my own chain .. by duplicating the clip and having one as a template, then another with a series of chains.. i then tweaked eeach chain to get the look from teh template clip.. took forever..
BUT IT WORKED>. this might be your best option considering ur GFX card and (maybe) budget..
I then upgrade to MB2 editors.. now this runs straight through your compatible GFX card and runs MB in realtime.. on my lappy i have a Nvidia Go7300 256mb 128bit card, and on the workstation, i have an Nvidia 6800GS/t 512mb ram, 256bit... Both give me faster than realtime performance with HDV... and DV of course.. i layer about 4 tracks (DV) with the filter and it doesnt skip a beat.. (havent tried mroe than that coz i didnt need it.. )
another thing i noticed, is that when i run the filter across the track as a track effect, it speeds up ALL the previews.. as the clip filters occur before the track filters, so as the chain hits the track filter and processed by MB, usually MB2 and the GFX card have done all teh maths, so my previes are perfect (irrespective of the clip filter) so thats another consideration...
Big bummer is that Misfire and Deartefact is still single threaded...
Old February 8th, 2007, 08:55 PM   #13
I took off all the magic filters on the new project I am working on and did CC with sony vegas (quickly but also looks good) and the render is just flying buy. I watched the frames count up with MB 1..............2.............3..........4 and so on. Without the MB filters and with Sony CC it is just flying bye.
Old February 9th, 2007, 08:24 AM   #14
Don
this is a great suggestion to render the file to AVI first (e.g. process the effects) then encode that. I find it easier to tweek the encoding that way, e.g. you can get your unencoded edit file done (edits, effects, etc.) then play with the encoding if you need to without re-rendering the effects (even if you just pull the AVI file back into your editor to encode it). It shouldn't be quicker in total (e.g. same math has to be done and in fact is a little more disk IO) but for some reason it's easier to deal with that way. good tip!
