UAD Cards won't work with Vegas 7.0??? at DVinfo.net
Old March 9th, 2007, 12:44 PM   #1
I have two separate UAD PCI plugin cards on two different computers and neither will work with Vegas 7.0. I get an "error 30" message on both which states there is a buffer mismatch. Anyone using UAD succesfully with 7.0?
Duane Adam is offline   Reply With Quote
Old March 10th, 2007, 02:19 AM   #2
I was getting some serious crashes and stopped using the plugins. I don’t know if it was a combination of items or the UAD plugs alone that were causing the problem.
James Binder is offline   Reply With Quote
Old March 10th, 2007, 10:05 AM   #3
I tried running these plugins with both computers using Vegas 6.0 and they run fine so 7.0 seems to be the culprit. After doing some research, this appears to be a problem with earlier Vegas versions so it's disappointining that the problem has re-appeared. I'm hopeful someone has found a solution...anyone?
