Shooting in 30P, editing in Vegas and Rendering at DVinfo.net
Old March 29th, 2007, 08:38 PM   #1
I noticed that when I Render after editing in Vegas, I find the file reading as 29.976i. i for interlaced I assume. I shot this in 30P. I just wondered is this how I should render or should I render in progressive? What would be the difference in my outcome? Thanks. J
John L. Miller is offline   Reply With Quote
Old March 29th, 2007, 08:45 PM   #2
to what format are you rendering? Print to tape? DVD? HD-DVD?
If you are rendering for DVD, then select the MainConcept template of your choosing (perhaps widescreen?) and then choose the Custom tab to render as 29.97, and change the field properties to "none." This will give you a 30p render. Be sure your project prop's are also 30p.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old March 29th, 2007, 09:06 PM   #3
I have been rendering for DVD. MPEG 2 to be exact. I guess I have been rendering in interlaced instead of Progressive because it is the default. I will try that and see the difference. thanks! J
