Multi Cam switcher at DVinfo.net
Old April 18th, 2007, 04:56 PM   #1
Multi Cam switcher
Is there any scripts or add-ons for Vegas supporting Multi-camera?
Matt Setnes is offline   Reply With Quote
Old April 18th, 2007, 05:16 PM   #2
If you want to switch between multiple cameras in post, I highly recommend the Excalibur script package:
http://www.jetdv.com/excalibur/multicam.php
If it's switching live on location you want, I can't help you there :-)
Cheers
Pat
PJ Gallagher is offline   Reply With Quote
Old April 19th, 2007, 03:57 AM   #3
There is also Ultimat S 3 from here:-
http://www.vasst.com/product.aspx?id...a-3ab01fee6db7
Multi-Cam makes life a LOT easier. Well worth it!
Alastair Brown is offline   Reply With Quote
Old April 19th, 2007, 04:13 AM   #4
There is also infinitiCAM, and DuoCam in addition to the Ultimate S 3.0 script that Alistair linked to.
DuoCAM is a two-camera switch that is free, and infinitiCAM is unlimited cameras, set up for 49 cams out of the box.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
Old April 26th, 2007, 08:37 PM   #5
Is it possible to create an EDL with any of these, while using live multicam?
Jack Smith is offline   Reply With Quote
Old April 27th, 2007, 01:17 PM   #6
I believe Vegas can export an EDL via its scripting (look under the scripting menu, NOT file-->save as). There is an article about someone using Vegas' multicam to edit, then bringing an EDL into Nitris DS.
2- I'm not sure what you mean by live. Vegas won't do live switching.
After ingest + setup however, you can switch at 2X real-time (or 4X, etc.) by playing the playhead faster (use the JKL keys, or set playback speed to a custom value).
Old April 27th, 2007, 11:04 PM   #7
Thanks Glenn.The link posted in Pat's post to excaliber says "Live Camera Switching (Vegas 6.0b or newer only) ".I was wondering if an EDL is available.
Old April 28th, 2007, 06:29 PM   #8
Sponsor: JET DV
You film the event. You capture the tapes. You put the tapes on the timeline and sync them (yes, the script helps with this process). Now you can play back the timeline and switch between the different camera angles live. It's not live switching DURING the event. For that, you need switching hardware.
Old April 28th, 2007, 10:49 PM   #9
Thanks for the explaination.
Old April 29th, 2007, 10:05 AM   #10
DuoCAM ?
Hi
Where can I free download the DuoCAM Vegas plugin?
Ron
Ron German is offline   Reply With Quote
Old April 29th, 2007, 12:47 PM   #11
Hi Ron -
Go to the vasst.com links and dig around - it's a 2 cam free version of their infincam (KILLER app if you need more than 2 cams for ANY mixdown!!). LOTS of great resources on that site!
DB>)
Old April 29th, 2007, 01:20 PM   #12
Thank you Dave
I have searched for DuoCAM in Vasst site and haven`t found the link to download it.
Best
Ron
Old April 29th, 2007, 08:36 PM   #13
Jack, did we answer your question?
2- Duocam should be here...
http://www.vasst.com/product.aspx?id...c-b54213315da5
Old April 30th, 2007, 07:35 AM   #14
Thank you Glenn
Ron
