Is the pre-render used by Vegas7 in the final render? at DVinfo.net
Old April 23rd, 2007, 01:38 PM   #1
This question was asked on the PP2 forum by Douglas Turner but I would like to know if the answer is the same for Vegas7.
Does Vegas7 use the pre-render when outputting to the final render?
Specifically, I use the cineform avi in the Vegas timeline, will pre-rendering any portion of the timeline speed up the final render time in Vegas7?
Cheers,
Robert
PS. Answer for PP2 is apparently .. no!
Robert Garvey Photographer
www.garvey.com.au
Robert Garvey is offline   Reply With Quote
Old April 23rd, 2007, 01:48 PM   #2
the answer to your question lies in the final output format. If you're outputting to a master format using the CineForm codec, then the answer is yes. If you're outputting to a master format of .m2t to print to tape, or to MPEG 2 for DVD delivery, the answer is no. Either way, you're moving/transcoding, so pre-rendering to one format doesn't benefit master render to a different format, regardless of what application you're using.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old April 23rd, 2007, 02:15 PM   #3
So can you change what you pre-render to? Say working with cineform avis but knowing output will be to one of the DVD Architect templates?
www.garvey.com.au
