What can 7.0 do with HDV that 6.0 can't? - Page 2 at DVinfo.net
Old May 8th, 2007, 06:05 PM   #16
Ok, I have defragged C:, moved swap file from C: to another drive, optimized my bios, rendered to different drives and I still can't render the original rendertest.veg in less than 27 seconds. However, I can render John Cline's new rendertest-hdv.veg in 155 seconds. Go figure (shrug).
Ok, thanks, John. I had the wrong output file format. Duh! Original rendertest.veg now renders in 12 sec. That's more like it.
Guy Bruner is offline   Reply With Quote
Old May 19th, 2007, 10:03 AM   #17
I have a P4 @ 2.8 ghz, will this be enough to run HDV (HV20 footage) smoothly with Vegas 7.0? As it stands right now, the footage can't run smoothly with Vegas 5.0 (my current system) so I'm hoping this is related to the version of Vegas that I have, and not my CPU.
Glenn Gipson is offline   Reply With Quote
Old May 19th, 2007, 10:51 AM   #18
Glen,
Vegas 7 handles HDV better than v.5, but I doubt you will be able to see enough improvement to make the experience better. My core 2 duo would edit it but not at full framerate in preview unless I went to draft mode. Putting it in Full (Best) would drag it to less than 10 fps. My quad core zips right through it with a single video track.
Old May 20th, 2007, 11:57 AM   #19
Originally Posted by Guy Bruner View Post
Glen,
So in other words, I'm going to need a Quad Core machine to edit HV20-1080-24f footage the way I use to edit SD?
Old May 20th, 2007, 12:02 PM   #20
Editing four streams of HDV mixed with XDCAM quite regularly with full/usually full frame playback at Preview/Auto, sized to half rez. This setting has always been the recommended playback in previous versions of Vegas, and still is.
You can edit HDV quite easily on any dual core machine, assuming you're not running antivirus or other background apps. Dual 270 machine (dual dual core) is a great way to work, we've got 5 of these machines running, and all are HDV or XDCAM on the timeline, all the time.
Faster is better, but not necessary. If you've got a dual core system, you should always be able to achieve full framerate playback at Preview/Auto
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old May 20th, 2007, 12:13 PM   #21
Thanks Douglas, that's good to know. I'm only looking to have one HDV track on my time line at once, along with six to eight other audio tracks. I'm only going to be performing simple cuts, fades, dissolves and some color correction.
Old May 30th, 2007, 11:55 AM   #22
Well, I just put Vegas 7.0 on my system before upgrading my hardware, and wow, what a difference! The HDV actually plays smoothly without the need for a new processor!
Old May 30th, 2007, 11:57 AM   #23
Well, it actually only plays smoothly in a small preview window. Where as before it wouldn't play at all.
Old May 30th, 2007, 01:37 PM   #24
It's nice when you get a big boost just from software. Save your money and there will be some fancy new quadcore processors late this year. They may even be affordable early next year. The best news for me is that the new quadcore chips (Penryn?) will be the same socket as my Core2Duo and much faster.
Marcus Marchesseault is offline   Reply
