Part Frame effects at DVinfo.net
Old May 30th, 2007, 07:45 AM   #1
Part Frame effects
I wish to alter brightness & contrast in just the top half of the frame in an event. Is this possible & if so how do I do it ? I assume you would open the "event pan crop " but what then ?
Ron Cooper
Ron Cooper is offline   Reply With Quote
Old May 30th, 2007, 08:29 AM   #2
Sponsor: JET DV
You'll need the clip on TWO tracks. On one of the tracks, apply the effect. On the other - don't. Now use masking (however you wish to apply it) to let the lower track appropriately show through as needed.
So, for example, on track one, have the clip with the effect applied.
On track two have the clip with no effects.
On track one, you could use the Pan/Crop Bezier masking to "cut out" the bottom half allowing the unaffected clip to show through in that area and even "feather" the edge.
Edward Troxel is offline   Reply
