XH A1 24p mode - capture at 29.97 fps? at DVinfo.net
Final Cut Suite
Old March 18th, 2008, 09:48 AM   #1
I recently submitted an email to canon asking them whay frame rate the A1 recorded at in 24p mode - 24fps or 23.98fps. this was their reply:
"Thank you for your inquiry on the precise frame rate in the XH A1. We
value you as a Canon customer and appreciate the opportunity to assist
you.
The camcorder records at the NTSC fixed rate of 29.97 fps."
I'm assuming that this has to do with the 2:3 pulldown thats added. My question is this:
Would the correct workflow be to have my Capture and Device Control presets at 29.97 and my sequence presets at 23.98? Since fcp automatically removes the pulldown wouldn't this be the correct setup? Will having my sequence presets different from my capture presets be a problem in this situation?
Cal Bickford is offline   Reply With Quote
Old March 18th, 2008, 10:09 AM   #2
I have only worked with 23.98 material a few times, but IIRC that is the way I did it and had no issues.
If in doubt, try capturing a little (say 10 minutes worth) and play it back in your timeline.
Here's one thing that comes to mind, however. I was working with Panasonic and JVC material using the Advanced pulldown. I don't know how the Canon cams are doing their pulldown. Hopefully someone who knows better than I will chine in on this.
Mike Barber
"I'm laughing to stop myself from screaming."
Mike Barber is offline   Reply With Quote
Old March 18th, 2008, 08:19 PM   #3
Ok This is definitely the correct way as this is how fcp's "hdv - 1080p24" preset is set up. For some reason I thought this preset also used 29.97 fps for the sequence rate (it uses 23.98 for seq, doesn't let you see/edit rate for capture, and sets device control rate to 29.97) and that confused me - but it turns out I was just confusing myself : )
Old March 18th, 2008, 09:02 PM   #4
Yeah, that never happens to me. ;-D
Mike Barber
