UV filter causes halos and disco effects at DVinfo.net
Old July 10th, 2004, 06:22 PM   #1
Has anyone else had any weird results from their
Canon UV filter. It seems like everytime I use it in poorly lit situations I get some weird halos or stobe effects around headlights and other flashing lights. I was thinking that I might have my f-stop set to low. It has happened a few times when I had the camera set up to f1.6-2, 1/30th-160th on the shutter, no gain, autofocus off, preset outdoor white balance. I have cleaned the lens and filter but they really werent that dirty. I have some frame grabs but I dont have a site to post at.
Ryan McBride is offline   Reply With Quote
Old July 10th, 2004, 09:39 PM   #2
Retired DV Info Net Almunus
This is common, particularly for dark scenes with bright points. Sometimes called "fireflies", it's caused by reflections bounced between the lens and the filter. Solution: take the filter off the lens.
Old July 10th, 2004, 10:41 PM   #3
Ryan,
Good quality COATED filters are less likely to cause this effect. May want to try a different filter.
Rob Wilson is offline   Reply With Quote
Old July 11th, 2004, 02:26 PM   #4
I had the same problems with a cheap UV filter. Now I am using a Hoya filter - works perfect, without halos and other unwanted effects.
Bernd
Bernd Binder is offline   Reply With Quote
Old July 11th, 2004, 06:54 PM   #5
Thanks a bunch for the input. I thought maybe since it was a Canon Filter it would be adequete, I recall it wasnt much money. I will try out another brand sometime soon.
