what to do on windy days? at DVinfo.net
Old September 15th, 2003, 10:59 AM   #1
11 sept. I bought my Canon xm-2.
And so far I am very satisfied with the picture quality!
But the first day I use my new camera it was a quite windy day, and though I set the microfone in "w.screen" it was a very disturbing result, not good at all.
So what to do on windy days?
I also consider to buy the DM-50 microfone, but can that microfone handle the problem with windy days better?
"The artist is nothing without the gift, but the gift is nothing without work."
Torsten Blomfeldt is offline   Reply With Quote
Old September 15th, 2003, 12:04 PM   #2
Old Boot
I gave up on the XM2 audio presets and went for a Senni setup with a foam cover PLUS a windjammer-type fluffy. I use this in conjunction with the MA-300.
Grazie
Old September 15th, 2003, 12:17 PM   #3
Torsten
I bought an inexpensive ($5.99) foam windscreen from Radio Shack (probably don't have a branch near you) and installed it over the GL2 onboard mic by using a tie wrap. I rarely use the onboard mic but it did help reduce wind noise significanlty. I can send a pic if you're interested.
Rob Wilson is offline   Reply With Quote
Old September 15th, 2003, 03:04 PM   #4
MikeMuff
Last week I ordered a MikeMuff since I was also disturbed by the ppor sound quality on my XM2. A few days ago I received it. But...minor point...no wind the last few days so I could not test it lol. Hope tomorrow will be a little windy so I can update you my results.
It looks nice on my cam..it fits like a glove. And if it does what they promise on their site, I am very happy.
Joris Beverloo is offline   Reply With Quote
Old September 15th, 2003, 06:03 PM   #5
Why not use a fan to test the MikeMuff?
dpalomaki@dspalomaki.com
Old September 17th, 2003, 01:21 PM   #6
I went with a Rycote mini-windjammer. They make one that fits the GL2, but sent me a size medium instead (it seems to be a little bigger than the one indicated for the GL2 because it fit very sloppy). That actually turned out for the better because I realized that it fit perfectly over one of those Radio Shack foam windscreens, and then onto the GL2 mic. Today is a fairly windy day, blowing at a steady 20mph, so I just tested it and that combination seemed to work well. All I could hear was street noise and the russling of leaves in the trees.
This is a very simple, low budget (about $50) solution, but it works well for what I need.
nicholi
Nicholi Brossia is offline   Reply With Quote
Old September 17th, 2003, 01:30 PM   #7
Retired DV Info Net Almunus
I second the vote for the Rycote mini-Windjammer. I just used mine this week to shoot a very short piece in a very windy setting. Although I'll not be using the audio from the footage I was really surprised at how good this fuzzy little mouse worked.
Rycote's larger muffs work extremely well for shotgun mics, btw.
Old September 17th, 2003, 09:51 PM   #8
On an added note, using the Rycote over the GL2 mic makes the camcorder look a lot more presentable. Its strange that its just that little piece, but I noticed right away, as well as others who have commented.
