Canon XL H1 picture sharpness and vivid colors
Hello All, I am new to DV Info and looking for some help from all of you experts. I owned a JVC GY-HD200U for about 2 years and enjoyed it. Just recently I upgraded to Canon XL H1A for my business. I have been shooting with camera and like the quality over all but I am not able to get the results same as JVC's picture quality and colors by default. On Canon the picture quality is good but I cannot make the picture sharp and crisp. I have tried many settings but still I cannot get sharpness. Picture is very clear but very soft at the same time. Other issue I am having is with the color settings. I am looking for vivid colors settings. I shoot Indian weddings which are very very colorful and my clients want to see all the colors. Can someone please advise me how to get sharp/crisp picture with vivid colors or guide me towards a preset that someone has? Any help would be greatly appreciated.
Cheers. |
Have you adjusted the back focus? check the manual for the instructions on this. Also a few threads down they discussed this issue.
I would definitely trying downloading some of the presets from this site. Try the presets from Stephen Dempsey (disjecta) called Panalook.
Thanks John. Yes I have already adjusted the back focus and it is fine. Please don’t get me wrong, the quality of the picture is okay but I would like it more if it was sharper with vivid colors.
As Mr. Sanders stated, the 'out of the box' look of video with the H1 is rather flat and dullish. But when you apply the wide range of customer presets you can greatly affect the look. I also recommend Steve Dempsey's presets to warm up colors and deepen them
You can also play around with the presets yourself in the menu to get just the looks you personally are going for. |
Yeah, the difference between the "out of the box" look and one that is "tuned" is...WOW!
Good evening,
If I recal, the reason they come out a bit flat oout of the box is so that thery is more area to move in post. The xl2 was the same. Having 6 presets available one should not have to do that at all and have presets for what ever he is about to encounter and have it closer right out of the camera. Which by the way, is the way we were taught to shoot film. |
Thanks guys. I got it to work with my own settings.
Can someone please tell me that under Custom Preset Parameters , what does setting “Black stretch/Black press” do? I am trying to make blacks darker/richer. What values should I increase/decrease? Thanks.
"PRESET13.CPF: OLEGWARM -- warm, saturated and film-like when combined with Skin Detail: Middle." http://www.dvinfo.net/conf/canon-xl-...d-library.html (Middle of Page) |
Low lighting shooting
Hello DV Info Expersts,
I am doing a wedding job this weekend. This will be heppening at a hotel and I am pretty sure that lighting will be low. Is there is a preset for low lighting shooting that I can use? Thanks to all in advance. Dil Singh |
Switch to 1/24th shutter BEFORE you start pushing the gain above +3db. You get a little more motion blur but you avoid the noise floor. And for a wedding video I don't think a little extra motion blur is a deal breaker (like it would be for narrative work).
When indoors try to avoid filtration as much as possible as you usually lose some light. |
Also, if you are using any of the presets that really crush the blacks or the pedestal is lowered, you might want to turn this off. I use the "Disjecta" preset which is great for well lit scenes, but find I gain about a stop of light back when I turn it off. I have a CP where I use the default camera settings but I change the knee setting to allow for better latitude. This is not ideal for every circumstance and doesn't yiled great color but when covering an event in average to low light it helps. Since it is so dim anyway you aren't getting very brilliant colors anyway. If you are shooting in 30P or 60i use the 1/30th shutter speed also.
Good Luck |
Good advice Marty. Turning off the presets that crush black should really help.
