Canon 3x wide angle lens - Page 12 at DVinfo.net
Old August 8th, 2005, 07:28 PM   #166
3x Wide angle HUGE PROBLEM!
It happened a few weeks ago and i still have not figured out what the problem was. I was shooting with the wide angle lens fine one day, then two days later I was on another shoot and it would not respond! I had no focus, zoom, or iris control at all with the lens. I am located in canada and the quickest that Canon said they could have it repaired is 4 weeks! I can't afford to send it away that long because i have shoots every week. Has ANYONE found this problem or heard of it!? I wish i was in the states so i could take advantage of the XL2 users club, we don't have that in Canada and it really really sucks right now...
Mikey Williams
Down To Earth Productions
Mikey Williams is offline   Reply With Quote
Old August 8th, 2005, 08:20 PM   #167
Never had it happen but sounds like repair is the only option... maybe find an adapter to tide you over...
ash =o)
Ash Greyson is offline   Reply With Quote
Old August 8th, 2005, 11:35 PM   #168
Built the VanceCam
If you haven't already, remove the lens and take a look at the gold contact pins in the mount. There's a slight chance that you have a bad contact due to dirt or a small foreign object. The fact that you've lost all functions suggests that it's either the power contact or the ground contact. If they all look okay, not much else you can do except send it in for repair.
Dan Vance is offline   Reply With Quote
Old August 9th, 2005, 01:15 PM   #169
Happened to me 1 month after I got my 3X
Did you accidentally remove it with the camera turned on? You blew the lens's main fuse.
Should be covered under warrenty.
Matthew Nayman is offline   Reply With Quote
Old August 9th, 2005, 10:10 PM   #170
i don't beleive i blew the cameras main fuse, cuz it works fine with my 16x manual lens and a borrowed 3x wide i tried out last weekend. The contacts look to be clean...i guess i'll have to try and send it in on it's own, cuz i can not afford to send the whole camera in to be repaired.
Mikey Williams
Old August 10th, 2005, 11:30 AM   #171
Not the cameras fuse, but the lenses. I don't know anything about the fuses on the lens, just repeating and clarifying what Mathew said
Joe Winchester is offline   Reply With Quote
Old August 10th, 2005, 08:36 PM   #172
My 3x developed the same problem today. I was shooting outside, and all of a sudden there was no zoom. I switched to my 20x, and it worked fine. When I got home tonight, I tried again, and realized that the zoom ring itself didn't work either( or the focus ring).
I checked the gold contacts and they look ok. Maybe I have a blown fuse also. I'll call Canon tommorrow.
Bruce S. Yarock
Bruce S. Yarock is offline   Reply With Quote
Old August 14th, 2005, 09:45 AM   #173
I've just got my 3X zoom back from repair after it threw it's hand in on the 16th July displaying all those faults mentioned eg no zoom, or focus. That repair, by Videotech near Manchester, took about two weeks, the lens being received back on the 28th. I was told a circuit board had failed. I didn't expect it to be turned round as quick as that.This was done under warranty. I'm very surprised to see so many of these lenses developing faults. On that day I was videoing at a motor race track up here in Scotland and had been swapping between the 20X and 3X but I can't remember if I changed lenses without powering down the XL2. I got the 3X lens at the beginning of the year from Warehouse Express after a lengthy wait which I assume was them waiting on new stock coming from Japan.
I'm going to get back in touch with Videotech tomorrow and see if they can give me a more detailed failure report.
Duncan Ross is offline   Reply With Quote
Old August 14th, 2005, 10:21 AM   #174
I brought mine to an authorized Canon repair facility in North Miami called "southern Photo". Very nice people, but had to leave it so they could diagnose the problem. I'll call them monday and mention the circuit board issue...Thanks Duncan.
Hopefully I'll have it back soon.
Bruce Yarock
Old August 15th, 2005, 08:25 AM   #175
Update...
Southern Photo just told me that the 3x has to go back to Canon. Apparantly they've been having some problems with a bad batch...
Bruce S. Yarock
Old August 15th, 2005, 09:30 AM   #176
Duncan and Bruce,
Any chance your serial numbers are sequential? Might be interesting to note where the 'bad batch' lies.
Richard Alvarez is offline   Reply With Quote
Old August 15th, 2005, 10:16 AM   #177
Just off the phone to Videotech. They had to replace the main PCB, which Canon UK supplied to them very quickly! Could it be that there is an known fault with a batch of these boards. This lens serial number is:0200228A.
I'd like to know why it failed and was it caused by changing the lens with the XL2 powered up??
Regards
Duncan Ross
Old August 15th, 2005, 11:41 AM   #178
Changing the lens with the power up can fry the camera fuse and/or the lens fuse. Always power down before changing lenses. ALSO NOTE. If you 'mis thread the lens'... you can damage the CCD block assembly, which is an expensive repair. Always 'match the red dots'.
Old August 15th, 2005, 08:43 PM   #179
Richard,
I'll post the serial # as soon as I find where I filed away the receipt....
Bruce yarock
Old August 16th, 2005, 01:08 AM   #180
I had the same problem with my XL1s recently using the standard 16X lens, I got the " check lens" message in the viewfinder, I could only zoom out but not in, auto focus had quit and auto iris stopped working. I loosened the lens and quickly retightened but this did not fix the problem. This problem occured before I loosened the lens so therefore was not caused by me.
The camera was sent back to Jessops who quoted me a minimum charge of £435 for repair. Luckily the camcorder is only 10 months old and has now been sent back to Canon for repair under warranty.
I know that it states in the instruction book that you should not remove the lens with the camcorder powered up, could this be a design fault on the part of Canon, the message in the viewfinder does not say " Power off camera and check lens".
If you notice the lens contacts have been "stepped" 2 of them are on a different level from the others, this looks to me as if Canon have designed the contacts so you can't accidently short the power contacts and cause this type of problem.
In short, I think this is a generic problem with the electronics in the Canon lenses and not caused by operator error, much like the " remove Tape" error with the XM2/GL2 camcorders.
I spoke to a " Stills" cameraman who works for our local newspaper, he uses a Canon with lenses that are compatable with the XL1 & XL2 camcorders with the same configuration of contacts, he changes lenses regularly without switching off his camera and has had no propblems.
David Morton is offline   Reply
