MB:LookSuite was designed for Video only ? or presets apply for Celluloid too ? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old March 11th, 2006, 11:08 PM   #1
I understand the purpose of LookSuite for Video.
But if LookSuite was designed to match some color deepness of 35mm stills, then i assume this filter will just hurt a picture that was already taken with a 35mm camera, right ?
If i'm wrong, and LookSuite Apply for 35mm too. I Guess that i have to match the colors of a 35mm still in my Video, before apply LookSuite. I'm a right ?
Sorry for the bad English.
I don't know if i explain myself right.
Roberto Lanczos is offline   Reply With Quote
Old March 13th, 2006, 04:01 PM   #2
Hi Roberto
I'm not an expert but I'm pretty sure the presets in the LookSuite would be a little too extreme for 35mm. However, if you were to water down the effects a little, I'm sure it would look just as good.
Again, I'm not an expert.
--Devereaux
http://geocities.com/anarchist_lb
Jon Laing is offline   Reply With Quote
Old March 14th, 2006, 12:03 AM   #3
I suppose, the presets are configured assuming that you're going to drop a shot with 1/60th on shutter, and well white balance.
But even with shots at 1/60, i felt like they're a little bit too extreme, like you said.
I'm not entirely sure about what direction would be best to tweak the colors before applying LookSuite.
But most of them, produce really high contrasts, and super darker areas.
I'm still trying to understand, for what type of sources are this presets for.
Old March 15th, 2006, 04:20 PM   #4
Roberto,
Look Suite is a really versitile tool. If you are only using the presets, you are missing out.
For one thing, Look Suite is for applying stylistic "looks" to your footage. It is not a replacement for proper color correction. It is designed to accept good-looking video that is of normal contrast and proper white balance, and enhance it in different ways.
If you find a look you want, but it doesn't look just right, perhaps your still image needs some work (adjust the Pre stage to taste), or the look is too extreme (adjust the Post stage to taste).
The default looks are quickly becoming cliche from overuse, so it's important to explore further.
Josh
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline   Reply With Quote
Old March 27th, 2006, 08:06 PM   #5
I've used it on super 8 footage and it looked fine.
ScapeFilms.com | My Photography | IMDB Profile
Mike Tesh is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
