Solutions for YPbPr capture to MBP at DVinfo.net
Open DV Discussion
Old October 27th, 2009, 02:37 PM   #1
Hi - I have the following situation:
Betacam SP tapes, need to ingest to FCP on a MBP
The tapes are old and we would like to get the highest quality capture we can, thus we are looking for a YPbPr instead of a composite or S-video solution. We'd also like to capture to uncompressed QuickTime files if possible, ideally 10-bit 4:2:2.
Based on my research, it seems as if the only solution for this is the Aja IO series, starting with the IO LA.
Am I missing any other manufacturers or solutions?
I'm in Jamaica, and so far have not uncovered a post house that can do this for me (BetaSP decks exist, but no one has the rest of the workflow, which is a bit mind-boggling to me)
thanx for any advice
Christopher Edmonds is offline   Reply With Quote
Old October 27th, 2009, 03:50 PM   #2
Blackmagic Design's Intensity Pro will do this.. up to HD resolutions. You'll need very fast disks.. possibly a Raid of some kind because Blackmagic's codec is a sort of non-compressed one. Price is low.. 199$ and works fine
Marcello Mazzilli is offline   Reply With Quote
Old October 27th, 2009, 04:12 PM   #3
Thanks - it needs to be a FW, USB or ExpressCard/34 solution though, as the target is a MacBook Pro (MBP)
Old October 27th, 2009, 04:18 PM   #4
I see... This is an alternative...
ADVC700
Old October 27th, 2009, 04:45 PM   #5
Please correct me if I am wrong, but this converts to a DV stream right?
Trying to avoid any compression in the process (the footage is all very short lengths, so disk space is not an issue)
Old October 27th, 2009, 04:49 PM   #6
Yes.. If you come from Beta SP it will be fine.
Anyway if you look on the web there are other solutions.. still. in the Mac World .. AJA is a good solution.
M
Old October 28th, 2009, 04:18 PM   #7
Also check this... HDMI and Analog I/O for Mac and PC - Matrox MXO2 Mini some guy posted it today on another thread and says works fine
Old November 6th, 2009, 07:10 PM   #8
For the record, in MY opinion, DV/DVCam is a MASSIVE quality hit coming from good quality, well shot BetaSP masters.
Old November 10th, 2009, 04:39 PM   #9
I dont have firsthand experience yet, but the matrox mx02 and mx02 mini look mighty promising. MX02 (non-mini) is a pretty versatile beast for U.S. $1500 and looks like it will not only capture your uncompressed SD from the betasp, but HD as well. Add a monitor and it should make FCP editing a lot snazzier as well.
Andrew Dean is offline   Reply With Quote
Old December 17th, 2009, 02:50 PM   #10
I read that the MX02 Mini will capture analog SD footage and "upconvert" it to HD with pillarboxing. Can it also capture/convert analog SD footage to straight SD video? Would like to make some standard 4:3 DVDs with my old analog footage that I won't be mixing with HD stuff. Would like to not have to drag this box and the canopus firewire converter around too.
Jason Lowe is offline   Reply
