May 27th, 2014, 04:47 PM | #1 |
GH4 4K for still frame captures
May 28th, 2014, 05:39 PM | #2 |
Re: GH4 4K for still frame captures
Here is a full size 4K UHD 3840x2160 desktop screenshot off my 4K UHD TV :
https://farm3.staticflickr.com/2927/...cfbbc6a6_o.jpg |
June 1st, 2014, 06:40 AM | #3 |
I'm very stoked about 4K and your photos are just one of the reasons why. It should be the end of the upward progression for a while, at least I hope. I read that 4K is close to the amount of detail that the human eye can resolve and that the eventual 8K should not be much of an improvement over 4K.
"The horror of what I saw on the timeline cannot be described." |
June 2nd, 2014, 09:52 AM | #4 |
June 2nd, 2014, 07:33 PM | #5 |
Those linked pictures are NOT 4K frame grabs, which should be 3840x2160. They are lower-resolution *screen* captures (2560x1600).
June 3rd, 2014, 06:49 AM | #6 |
June 3rd, 2014, 09:26 AM | #7 |
What shutter speed for the bicycle footage?
Obviously if it's only for stills, the fast shutter speed makes sense - the problem is when you also want normal looking (non-choppy) video motion. |
June 3rd, 2014, 01:59 PM | #8 |
Unfortunately, with action, those two purposes don't go together. Either you are filming for motion or you are filming for stills. High shutter rates don't make for great motion filming except for quick inserts. And filming for stills might pose an issue in low-light situations. Non-action filming shouldn't be a problem.
William Hohauser - New York City Producer/Edit/Camera/Animation |
June 3rd, 2014, 07:47 PM | #9 |
One of the exceptions to the action stills from video that interests me particularly is my aviation work. Low shutter speed does wonders for heli's and blurring backgrounds assuming your panning skills are worthy!
These are 1080p cropped a bit from my C100 but I plan to do the same with a GH4 very soon! http://yipdog.smugmug.com/Airplanes/...2/CSA-1-X2.jpg http://yipdog.smugmug.com/Airplanes/...Rolling-X2.jpg
The older I get, the better I was! |
June 4th, 2014, 06:24 AM | #10 | |
"The resolution test of the Leica DG Nocticron 42.5 mm f/1.2 Asph. P.O.I.S. was based on RAW files from the Olympus E-PL1. In the case of that body the highest results, reached by the best fixed focus lenses, amount to about 80 lpmm (and the record value of 82.6 lpmm belongs to the Voigtlander 0.95/25, with the Olympus 1.8/75 not far behind).The decency level is set near 44-45 lpmm." Panasonic Leica DG Nocticron 42.5 mm f/1.2 Asph. P.O.I.S. review - Image resolution - Lenstip.com |
June 4th, 2014, 07:31 AM | #11 | |
You should be able to get away with a large number of grab-able stills with that kind of motion at 1/500ish. Did you do some tests to see the slowest shutter that would work for your needs? If you need every single frame grab-able, then you're stuck in that super high arena, but if you can be fine with say 50% of frames grab-able, you can dial in a shutter speed that won't look quite so stark. Then again, there's always adding motion blur in post |
June 5th, 2014, 06:39 AM | #12 | |
