Got my NX5u footage... at DVinfo.net
Sony NXCAM / AVCHD Camcorders
Old April 18th, 2012, 11:48 AM   #1
I had a chance to go into B&H yesterday and record some test standard def footage. I was able to take the sd footage and bring it into Windows 7 and use windows DVD creator to easily and quickly burn a DVD.
The only issue that concerned me was when I was trying to set the recording modes of the camera. Is it true that you cannot record standard def to both the Sd card and the flash memory unit? The only settings I could see were HD HD, HD SD and SD HD.
Also I'm assumIng that you cannot record to both SD slots at the same time? Making a backup.
Rob
Robert Rinkewich is offline   Reply With Quote
Old April 18th, 2012, 02:45 PM   #2
Re: Got my NX5u footage...
Robert, record in HD on the flask memory unit and keep it as back-up. This way you have SD on the cards and you have both HD and SD on the flash memory. Why? Because you can convert the HD to SD but not the other way around.
stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old April 18th, 2012, 02:56 PM   #3
Strips
Thanks for the reply. But I have a specific need for two sd recordings. We provide DVDs on site at sporting events. We want to be able to burn sd straight to DVD with as little processing as possible. The sd footage I got at B&H works great for me.
So I guess two sd recordings is impossible with this camera?
Robert
Old April 18th, 2012, 04:27 PM   #4
Yes that is true. But if you have a FMU128 and cards in both card slots you have the option of taking a card out and recording to the other while still recoding to the FMU. You can't record two different things at the same time anyway and you can always switch cards if you want to record something else. A few card will allow you to keep switching and going to the PC to make a DVD. Making two copies on a PC is very fast. I think this is exactly what Daniel does. Hopefully he will respond and tell you how he does this.
Ron Evans
Ron Evans is offline   Reply
