EX1 Music Video at DVinfo.net
Old August 15th, 2008, 03:55 PM   #1
EX1 Music Video
I shoot a music video on the EX1 and ended up buying one for a 6 month web project I was hired to do.
The EX1 project is under both the DP and Director section (see if you can work out the navigation he he..)
Home Adam's website
The video is for Craine "end of the line"
I used the EX1 as I needed good low light capability's on a budget and on this project I wanted something that was small and simple to handle as I was wearing a few too many hats :-)
The Video is based on some animation that was rear projected behind the performers in a empty warehouse. I got one of the brightest projectors I could find for less than £1000 a day rental.
originally I planed to have a LCD display behing the band but it was too costly. I think it worked out well as I feel the plastic sheeting and powerful projector give a unique look as it illuminates the picture and acts as a back light. on the day I found that I needed the throw a bit more back light on the band so I used a couple of pups as well. but other than that all the light is from the projector.
I used floor underlay as the backdrop as it was the biggest semi-transparent plastic I could find that matched the tight budget.
I think the track made it to 7 on the UK indie chart (BBC)
Adam Levins is offline   Reply With Quote
Old August 15th, 2008, 07:51 PM   #2
Loved it, and like your other work too.
Makes me want to shoot music video's.
Where did you get the animation from?
Todd Moore is offline   Reply With Quote
Old August 16th, 2008, 01:14 AM   #3
Nice ...
Good imagery and good steady cam on the short film!
Dean Harrington is offline   Reply With Quote
Old August 18th, 2008, 04:59 PM   #4
Hi Todd,
It was mostly created by Ben King (editor) in after effects and editied in FCP by myself. We also used a few particle generators.
Old September 5th, 2008, 04:27 PM   #5
Adam, great work! Is all of the movies shot with the EX1 alone? Are you using a adapter like the M2 or is it just a "clean" EX1?
Once again, wounderful work!
Regards / Jimmy
Jimmy Alenius is offline   Reply With Quote
Old June 9th, 2009, 12:10 AM   #6
Thanks Jimmy,
Yes that video was all EX1. I also filmed a Doc in Brazil on the EX1. It is towards the end in my 2009 showreel which you can find here: Adam Levins June 2009 Showreel on Vimeo
Cheers, Adam
