MVC Splitter at DVinfo.net
Old April 6th, 2012, 09:49 AM   #1
MVC Splitter
Does anyone happen to know if you pay a transcode penalty when demuxing MCV into dual AVCHD files using either Sony's Content Management Utility or Panasonic's HD Writer XE?
There is the possibility that these utilities separate the MVC file without transcoding - but - I'd sure like to know for sure.
David M. Cole is offline   Reply With Quote
Old April 12th, 2012, 02:56 PM   #2
Re: MVC Splitter
David, if you look at the thread I started a few months ago
http://www.dvinfo.net/forum/3d-stere...ion-tests.html
wherein I posted some pictures of resolution tests, you will find a picture of a resolution chart for the Sony NX3D1 camera left & right data. These L/R streams were decoded with Sony Content Management Utility and seem to display no resolution loss between the full resolution Left and the processed Delta Right frames. The frames come out of the MVC format as separate L/R MTS files when using Sony CMU to process.
Old April 13th, 2012, 07:43 AM   #3
Re: MVC Splitter
Thanks, Bruce. Unfortunately, a transcode generational loss may or may not be apparent on a resolution chart test (could be i-frame we're looking at).
Here's the thing... the reference codec for MVC (JMVC) can only decode MVC back to a raw image sequence. There is no reference provided for splitting a muxed MVC stream into 2 representative AVCHD streams without transcoding. It's easy to get one stream out without transcoding (because one stream is simply an AVCHD stream). Our engineers say it IS possible (and non-trivial) to extract the dependent stream without transcoding too, if you deeply parse the reference frame structure and build the dual stream GOP structure accordingly.
So... inquiring minds want to know... are we losing a generation w/ these utilities or not. If so, it argues to use GoPro Studio to transcode into Cineform or Peter Wimmer's utility to split into an uncompressed format for critical footage.
Old April 13th, 2012, 07:26 PM   #4
Re: MVC Splitter
I use Go Pro Studio Premium to mux and edit Panasonic 3DA1 footage. Their new version doesn't yet fully support MVC files but I'm told that it's coming Real Soon Now. In the meantime I'm splitting out L/R with Sony CMU and muxing into Cineform with GPSP manually.
Old April 14th, 2012, 06:32 AM   #5
Re: MVC Splitter
The PC version of GoPro Studio Premium and Pro support MVC now.
Old April 14th, 2012, 07:59 PM   #6
Re: MVC Splitter
Yes, their PC versions always are ahead of the OS X versions.
Old April 15th, 2012, 07:51 AM   #7
Re: MVC Splitter
At least they have OS X versions, unlike *cough* Edius :)
Neil Richards is offline   Reply
