Why is my 1024x768 AVI cropped when I import it? at DVinfo.net
Adobe Creative Suite
Old November 12th, 2007, 05:01 PM   #1
I created a video (avi) with a resolution of 1024x768. But when I import it in to PP(CS3), the video is cropped? How do I prevent this from happening?
Ming Dong is offline   Reply With Quote
Old November 16th, 2007, 10:07 AM   #2
Hi Ming,
Is this SD or HD? And what resolution?
Is your project widescreen (16:9) or standard (4:3)? If it's widescreen, you won't fill the sides of the screen unless you stretch it.
I think the video is not being scaled down, it's being displayed in original size, but your video settings are lower than 1024x768, so it appears cropped. Perhaps it's just occupying a larger area than your video size contains? You can either scale it down manually, or I believe you can right click on the footage in the file bin and set it to match the project size, which will scale it down automatically. That's a better option for multiple clips because you can select them all and then scale them all at once.
If this is a 720x480 project, 800x600 might be a better choice, as there's less blurring when scaling down, because it's scaling a lower percentage.
Hope this helps! :)
Eric
Eric Shepherd is offline   Reply
