Adobe Premiere CS3 Encoder Problem at DVinfo.net
Adobe Creative Suite
Old December 3rd, 2007, 10:58 AM   #1
When I click on the encoder tab to make my avi into a flash video it shuts down premiere. It would appear that Oncore & onlocation works fine. I am wondering if i should just go back to Pro2. The upgrade was free, hopefully this is not a case of you get what you pay for. Thanks for looking and look forward to any input about CS3.
Bob
Bob Campbell is offline   Reply With Quote
Old December 3rd, 2007, 11:52 AM   #2
You will probably get more feedback if a moderator moves this thread to the Premiere subforum.
Old December 3rd, 2007, 04:42 PM   #3
Done. Moved from XL2 Watchdog forum to the Premiere forum.
Pete Bauer
Old December 3rd, 2007, 05:26 PM   #4
I cant make flash videos from avis in CS3. Im using Cineform Prospect.
I make them in Quicktime... a bit shame for Premiere.
Hernan Vilchez
kabopro.com myspace.com/kabopro
Hernan Vilchez is offline   Reply With Quote
Old December 4th, 2007, 11:51 PM   #5
My guess is that the adobe media encoder is crashing because it is trying to initialize libguide.lib when libguide40.lib is already initialized .... quite a few people have had this same problem.
If so, the fix is to add a new environment variable called KMP_DUPLICATE_LIB_OK and set its value as TRUE ... flash export worked fine for me after I did that.
To add an environmental variable in Windows XP, go to the Control Panel/System/Advanced tab.
Hope that helps.
Old December 5th, 2007, 11:35 AM   #6
Thanks for your help, Graham. I did put the environmental variable in and it did not seem to help. However, I’m not sure that is my problem. Perhaps I explained the problem wrong the first time. I’ll try again.
When I am in the Premiere CS3 edit timeline, I click on the file tab, then export file, and lastly click on adobe encoder. That’s seems to be when my problem shows up. When I click on the encoder button the entire Adobe Premiere CS3 program shuts down.
Thanks to everyone for all the help.
Bob
Old December 6th, 2007, 05:48 AM   #7
Hope that helps.
Thanks a lot Graham, that solved my problem! Now i can finally export flv files from Premiere CS3.
Hernan Vilchez
Old December 6th, 2007, 07:43 AM   #8
Hernan - just out of interest, do you have both PPro2 and PProCS3 installed? I do, and wondered if that was why I ran into this "duplicate" problem...
Old December 6th, 2007, 09:11 AM   #9
Problem solved
Well, QuickTime was the problem. It was not downloaded correctly. Installed it again and it works fine. I did put in the environmental variable. Just to be safe. Hopefully there will be no more crashing. Thanks again for all the help.
bob
