HV20 not working with PP1.5 at DVinfo.net
Adobe Creative Suite
Old January 14th, 2008, 02:56 PM   #1
PremiereP 1.5 is not recognizing my HV20.
I have added the 1.5.1 update.
I know that the firewire link works because I can download video in Win Movie Maker.
I get the feeling I need a patch or my camera settings are wrong.
I don't see the HV20 as a choice in the capture settings.
I have been using Canon generic for the camera of choice in capture settings.
I also notice that you can set the setting to DV or HDV when starting a new project. I tried both. No luck.
I could get some connection, but only when the camera was set on HDV instead of SD format, and Premiere capture setting was set on HDV. But the connection was awful. I recorded a little with the tape button, but was too slow and looked flawed.
What I really want to do is use the camera for SD format editing.
This is for a non-profit community center video class that was supposed to start last week. Help.
Any suggestions would be greatly appreciated.
Al
Alfred Diaz is offline   Reply With Quote
Old January 14th, 2008, 03:27 PM   #2
Make sure the "Device Control" settings in your capture window are set to HDV or DV, whichever the cam and project are.
When the SW doesn't see the cam and you know your FW is okay at both ends, a settings mismatch is often the problem.
Old January 15th, 2008, 09:48 PM   #3
Adam,
I did do that. As I wrote in the original post, I tried with the camera set to HDV and the PP capture device settings on HDV, then I tried again with the camera set on SD and the PP capture device set on DV.
I got no connection with DV settings. But I could get a picture with HDV settings. But it was slow and flawed.
Also, what camera should I be chosing. I have been chosing Canon standard. Shouldn't I actually see my camera as a choice there?
Do I need to download a driver from Canon?
Thanks.
Al
Old January 16th, 2008, 01:32 PM   #4
Your camera hadn't been developed when PPro 1.5.1 was released back in 2005. The only HDV cameras back then were the JVC GR100 and the Sony FX1. No guarentee that it will work, but it might. The HDV features in PPro 1.5.1 were actually developed by Cineform, so that might be something to consider as well.
For more information on these topics, check out my tech website at www.hd4pc.com
Mike McCarthy is offline   Reply With Quote
Old January 16th, 2008, 09:54 PM   #5
Mike,
Do I need to install Aspect HD for Premiere Pro 2.0 (which is suppose to work on PP1.5)?
Also, I notice in the system requiremets that I am supposed to have Windows XP SP2. I need to check the class computers to make sure they have been upgraded. But I think they have been.
So is Cineform the same as Aspect HD?
There is a fifteen day trial, so I can always download as see how it works.
Thanks.
Any tips you and anyone else has are greatly appreciated.
Al
Old January 17th, 2008, 02:05 PM   #6
Aspect should help, but you will be limited to the trial time.
Old January 19th, 2008, 09:15 PM   #7
Just tried to download video from a Canon 7R65. I had the same problem. Whether it is the HV20 or ZR65, the computer says there is a problem connecting, and to restart the camera. I can control the both cameras, but nothing apprears in the capture mode. I think the problem may be with some sort of MicroSoft filter. I am going to call some tech guys who worked on the computer. I will let you guys now the problem once I figure it out. I may still need to get Cineform, but it's pointless right now until I can atleast connect with my ZR65, which is a pretty simple camera.
Let you know what happens soon as I figure it out.
Al
Old January 19th, 2008, 11:53 PM   #8
Images: 18
Hi Alfred...........
Try downloading the Ulead Video Studio trial AND the Premier Elements trial and see if either of them will jump start this thing.
I've known nonworking systems (with camera downloads) to spring into life when another app is loaded and mysteriously keep working when the trial is over and the app removed.
Nothing to lose but some download time.
CS
Old February 2nd, 2008, 02:28 AM   #9
a solution a last
Been a while, but I finally got the tech guys to look at the computers. It turns out that the computers were missing dozens of updates for Windows.
I tried again after the updates were installed, and it worked.
So that was the problem all along.
Thanks guys.
Alfred Diaz
www.advideoproductions.com
