Serious Magic DVRack - Page 5 at DVinfo.net
Adobe Creative Suite
Old November 27th, 2004, 12:49 PM   #61
Contributor
I have never tried it. However similar setups have been discussed before. It seems that what you get in that mode through Firewire is a less than optimal deinterlaced, downscaled DV image. The deinterlacing algorithm reduces resolution, and then you will lose even more if you crop the image for 16:9. It's not the same as being able to access 30 still frames per seconds from the camera's photo mode, that would be great and you would have enough resolution to work with in native 16:9 DV afterwards. But this camera can't do that. You are better of using the camera in 16:9 DV mode, which is actually very good. I have not used DV Rack but I imagine it must be able to deal with 16:9 DV.
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply With Quote
Old November 27th, 2004, 01:52 PM   #62
Yeah, originally some people thought they were getting 30p full resolution images, but that turned out to be optimistic. I tried this myself, and even though I didn't study the captured results, I could tell on the monitor that they were pretty bad. I think I was seeing the same low res image the camera displays on its LCD screen. For example, if you went into the photo mode menus the image shown via the firewire port was identical to the LCD screen, complete with text and menus. I'd guess it was 640x480, and possibly at a low frame rate also. Right away I decided it wasn't worth further exploration. But if you liked what you saw then give it a shot and let us know how it turns out.
Old November 28th, 2004, 05:03 PM   #63
Thanks, I thought I was onto something, guess not.
Cliff Hepburn is offline   Reply With Quote
Old November 28th, 2004, 05:17 PM   #64
Interesting
Interesting thread. I am a real newbie at video. However, I have been playing around with capture from my Canon Optura 300 direct to my new computer I put together. I put the Optura on still photo mode and use Vegas to capture to disk in Dv format. My family actually looked at some video transfered from the Canon to the hard drive via firewire then at some video captured to disk with the 300 on still photo mode with the SD card out of the camera. Many people asked me why the direct to disk in still camera mode looks so vivid, clear and sharp looking. I wanted to put a firewire card in my wife's laptop and use the camera on the go like that. One big problem I have is finding the best program or encoder to encode Mpeg2. My DVD renders lose quality from the original. Especially when viewing a moving subject. This is the biggest issue I see with the consumer market for archiving DV or even older home video to DVD.
Michael Sinclair is offline   Reply With Quote
Old November 30th, 2004, 10:50 PM   #65
Dv Rack
testing
no way to see camera menus on dv rack?
Kent Dammand is offline   Reply With Quote
Old December 1st, 2004, 06:41 AM   #66
Re: Dv Rack
<<<-- Originally posted by Kent Dammand : testing
no way to see camera menus on dv rack? -->>>
Depending on the camera, I think there is, but why would you want to?
If you do, then the menus could get recorded as well as the video.
There should be a menu item to send it out.
Danny Fye
www.dannyfye.com
Danny Fye is offline   Reply With Quote
Old December 1st, 2004, 04:14 PM   #67
Camera menus, at least on my XL1S, can be sent out on the analog outputs, but not on the firewire output. I don't know if that is the same with all camreas though.
Ed Frazier
Ed Frazier is offline   Reply With Quote
Old December 1st, 2004, 07:20 PM   #68
Barry Wan Kenobi
On the DVX you can't send the menus out the firewire either. I can't think of a camera that does allow it, so I'm guessing that no, there will be no way to see the menus on the DV Rack monitor...
Old December 1st, 2004, 08:10 PM   #69
<<<-- Originally posted by Barry Green : On the DVX you can't send the menus out the firewire either. I can't think of a camera that does allow it, so I'm guessing that no, there will be no way to see the menus on the DV Rack monitor... -->>>
I guess the question now is why would one want to?
Danny Fye
www.dannyfye.com
Old December 11th, 2004, 06:02 PM   #70
DV Rack Recording Tool
We are currently in heavy testing of Serious Magic's DV Rack. The software loads on any PC Laptop (over 1.2 GHz) and enables you to record from a DV camcoder and monitor the following:
Monitor with safe area, zebra patterns, 16x9 mask, undescan, and calibrated brightness, chroma, phase, and contrast. The software also provides the ability to frame grab, view time code and view waveform monitor and vector scope. It also contains a video analyzer (5 color spaces).
The recorder saves in avi1, avi2, QT, Canopus, and Matrox DV formats. it supports PAL and NTSC video standards, but does not support HDV strams at this time.
2 week trial is available by download. Price is $500 US
http://www.seriousmagic.com/dvrack.cfm
Very interesting.
Paul
Paul Matwiy is offline   Reply With Quote
Old December 11th, 2004, 07:31 PM   #71
Barry Wan Kenobi
Even more interesting is that they've announced a "lite" version of DV Rack, which primarily gives the field monitor and disk recorder, for just $99. A lot of features are stripped down, but for $99, it's very interesting indeed.
Old December 11th, 2004, 08:57 PM   #72
Ahh, DV rack looks like such a great program. Now, all I need is a laptop....Ehh, and 500$. :\
Travis Maynard is offline   Reply With Quote
Old December 14th, 2004, 07:59 AM   #73
RED Code Chef
The program has been discussed quite a lot here on DVInfo
already, check out the following threads:
http://www.dvinfo.net/conf/showthrea...threadid=35171
http://www.dvinfo.net/conf/showthrea...threadid=25742
Rob Lohman, visuar@iname.com
Old December 15th, 2004, 01:42 AM   #74
Does DV Rack or any other software has a buffer? (That is, when you start to record, it will store also the previous 5-30 seconds)
Lauri Kettunen is offline   Reply With Quote
Old December 15th, 2004, 06:05 AM   #75
RED Code Chef
The DV Racks feature page clearly states:
Never miss the beginning of a shot again with the Pre-record Buffer in the DVR. It can be be set to start the clip up to 30 seconds before you hit the Record button on your camera
Source: http://www.seriousmagic.com/dvrack/f...20benefits.cfm
