Problems copying & pasting audio between projects at DVinfo.net
Adobe Creative Suite
Old November 3rd, 2009, 10:06 PM   #1
Has anyone encountered the inability to copy audio from a sequence/timeline in one project to another?
I am trying to create a compilation using footage from several projects. When I copy content from a timeline/sequence from one project & then open a new project and paste into a new timeline/sequence the video portion is copied but the audio has gone, the block exists in the timeline but there is no waveform or sound (original footage has only one video and one stereo audio track - no transitions or effects added).
There must be a way to do this - any ideas? I have to render portion wanted as a movie and then import to new project - a time consuming solution!!
This has occured with P Pro 2 / CS2 / CS3 but I haven't ever worked around it.
Cheers
Matthew Cairns is offline   Reply With Quote
Old November 3rd, 2009, 10:45 PM   #2
Do you have Soundbooth?
If so, highlight the audio portion you wish to use in your original project. Right click it and select "Render and Replace". This will open Soundbooth and open that audio portion in Soundbooth. Then just click "File" and choose "Save As". This will save the audio as a separate file, that can then be imported back to Premiere ands used in any other project.
If you have Soundbooth......
If not, can you save just the audio portion as a .wav or .mp3 and then import it into the new project?
James Workman is offline   Reply
